Cracked FUTURE
Cracked FUTURE
Posted by Anonymous on Sunday, October 23, 2005 7:07 AM
A friend of mine Posted this on a local forum:
QUOTE: I use FUTURE to coat my car body before and after applying decals.....
it gives my car a very shiny finish and am very satisfied witht he results.
It has been a month or two since i placed the finished model on my display stand when i noticed that the model has FINE CRACKS or what you would normally see when a river dries and the soil or ground cracks from the sun or heat. although it is not all around the body of my model but only on certain parts. It is specially noticeable on cetain angles.
WHY DOES THIS HAPPEN?
I paint using Tamiya acrylics and i let it dry a couple of days, weeks even before applying Future. I always make sure that everything is completely dry before continuing at any step of painting....
Am i doing something wrong? or is Future not suitable for our climate and therefore i should switch to using Tamiya Clear instead...
HELP ME GUYS!!!!!!
Was it the Humidity inside the display case that did this?(i live in a place where it's 28-34 degreees celcius for most of the year) or was it the thickness on how he applied it? he said he applied the future in "coats"..
QUOTE: I have an airplane lying around on my workbench for more than two months with the same amount of Future top coat on it like the ones inside my diplay case and its perfectly OK..no cracks whatsoever!!!
i'm really bothered by this and i have no explanation on why it happened.. thought i'd ask the experts here at he forum..any thoughts would be greatly appreciated
Smile [:)]
    September 2005
Posted by nathaniel on Sunday, October 23, 2005 2:40 PM
From doing pottery, I've learned that the term for this is "crazing" and it happens when layers don't shrink at the same rate. So if you have a bowl or a mug and you put the glaze on, and the stoneware mug shrinks faster or slower than the glass glaze, you get the cracks.
The same applies to models. The curing of the paint/future can lead to one not shrinking/fitting at the same rate as the other. Rapid temperature changes can also cause this. It could have something to do with the humidity as well-- as this can effect the way the future dries. Have the models been through rapid temperature changes?
I'd recommend trying out thinning the future 4 parts future, 1 part 91% (or higher) Isopropyl alcohol (which is also a great thinner for Tamiya acrylics). Don't bother with the 70% stuff.
Future sort of disolves itself and fills in cracks in it's own finish. You can likely put another coat over the crazed surface and it might correct it. The worst case scenario would be that you'll have to remove the future, lose the decals and have to do that again. Windex will remove the future. Just spray it on like you're cleaning a window and wipe it off 30 seconds later. It may take more than one application.
Also, search the forums for this as well-- I'm sure you'll get further advice.
Nathaniel
    January 2004
Posted by MusicCity on Sunday, October 23, 2005 3:14 PM
I agree with Nathaniel, although I've never seen a need to thin Future. It's just the differing rates at which the paints cured. Another coat of Future should fix the problem.
Posted by Anonymous on Sunday, October 23, 2005 6:01 PM
thanks nat, we only have access to 70% isopropyl alcohol.. what are our alternatives? windex? do hobby shops carry the 91%? thanks a lot.
    July 2004
Posted by tho9900 on Sunday, October 23, 2005 8:05 PM
Luis - a lot of pharmacies carry 91% iso... if you don't see it ask at the counter as they might sell it from a bulk bottle... if you do happen to already have some Tamiya thinner that will work as well.. a little more expensive but it will work. (the acrylic thinner)
    December 2003
Posted by thevinman on Sunday, October 23, 2005 8:13 PM
I use 1 drop of windex in the airbrush cup when I shoot future. I find it helps thin it out.
Posted by Anonymous on Sunday, October 23, 2005 10:27 PM
thanks tom, i happen to have tamiya acrylic thinner because i primarily use tamiya and Gunze paints. i want to be a believer in future really, it's cheap and does the job properly. i have used it on some of my models already. i used to use just tamiya clear till i found out about future.
i really love my models and would like to make sure there are no foul ups for years to come..
Posted by Anonymous on Wednesday, October 26, 2005 5:09 AM
will windex or any glass cleaner with ammonia work the same as the tamiya acrylic thinner for this cracking problem?
