What's the best way to mask for painting?
Posted by Lufbery on Friday, July 18, 2003 9:51 AM
All,
I'm wondering what methods you use to mask while painting.
For example, I'm working on a 1/72 scale F-4 Phantom. It will have a light gull grey top and gloss white underside. I can see already that, unless I mask the top wing and fuselage somehow, I'm going to get overspray on it when I spray the bottom of the wing and fuselage.
Is there a relatively easy way to mask off what I'm not painting, short of wrapping the whole fuselage and upper wing in masking tape?
Regards,
-Drew
-Drew
Build what you like; like what you build.
Posted by Lufbery on Monday, July 21, 2003 8:17 AM
Wow, doesn't anyone mask when painting?
One thing I thought of doing was to cut paper in the size and shape of the top wing (for example) and just use masking tape on the edges. Has anyone done something like this?
Regards,
-Drew
-Drew
Posted by Anonymous on Monday, July 21, 2003 9:03 AM
if you place the model upside down so that the wings are supported and the top of the tailfin rests flat on the table.. you will be able to airbrush the bottom colour with little or no overspray..if you keep the nozzle of the airbrush directly overhead...when its dry turn it over and repeat with the darker colour.. this works well especially if you need softer demarcation between the colours.. if you need hard edges go for a masking tape... another tip to avoid overspray is to make yourself a little cardboard shield.. the card in the bottoms of biscuit packets [wagonwheels penguins etc] are good for this... and use it to block the overspray as you go along....
    June 2003
Posted by allan on Monday, July 21, 2003 10:47 AM
Deakon's right. Turning the model upside down will prevent or minimize overspray. But shouldnt you be spraying the white undersides first? You can then use the technique as laid down by Deakon on the top side.
You may not always avoid overspray altogether. Even with masks (by the way, try getting low-tack masking tape or theres a danger the mask will peel paint off the surface). You might have to re-paint areas with overspray using a fine nozzle.
Hope this helps.
No bucks, no Buck Rogers
Posted by Lufbery on Monday, July 21, 2003 3:33 PM
Thanks guys.
You're right, I should be painting the white first. But, it's a gloss paint, and I don't want to paint the flat paint over top of it if I can avoid that. At least, I thought paint flat over gloss could cause some problems. Will it?
Regards,
-Drew
-Drew
Posted by jridge on Monday, July 21, 2003 4:24 PM
Use Tamiya masking tape. It's low tack - won't pull paint off. Cut paper templates or use sticky notes so you don't have to mummify the model with tape. You can also use Saran Wrap or the plastic bags from the cleaners to protect large areas from overspray.
Jim The fate of the Chambermaid http://30thbg.1hwy.com/38thBS.html
Posted by wayne baker on Tuesday, July 22, 2003 7:34 AM
Use a flat white on the bottom also. There is another thread about hard to dry insignia white, where he was using a gloss. You have to gloss the top to apply decals. Do the bottom at the same time.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by Lufbery on Tuesday, July 22, 2003 8:34 AM
Jridge: thanks for the tips. One tip I read that I'm going to try is painting the nose cone of my F-4 by sticking it out the end of a bag that covers the whole rest of the model.
Wayne: I just found that thread you mentioned and read through it. Flat white it will be.
Regards,
-Drew
-Drew
