Can you spray Tamiya smoke?...
Posted by ipms40049 on Monday, October 31, 2005 1:29 AM
.. and does anyone have any tips?
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
    May 2005
Posted by Bgrigg on Monday, October 31, 2005 8:37 AM
Thin a bit and spray? I've only used smoke as a brushed on weathering technique, but I can't see any reason not to load up the trusty AB and shoot. Be careful though, you wouldn't want to be left holding a smoking gun! Tongue [:P]
Sorry about that last bit. I couldn't resist.
So long folks!
Posted by Anonymous on Tuesday, November 1, 2005 8:03 PM
You sure can and the results are pretty nice. Just make sure you get the right thinning ratio. It took me a couple of sprays to find just the right mix. I use about 55-45 thinner to paint. Use Tamiya thinner
    August 2005
Posted by eizzle on Friday, November 4, 2005 9:45 PM
I have sprayed it, and got good results. It worked great to tint headlight lenses. Somebody makes an aresol smoke (modelmaster? made by testors?) I think Tamiya even offers there smoke in a rattle can.
Colin
 Homer Simpson for president!!!
Posted by Anonymous on Saturday, November 5, 2005 7:43 AM
AB it for exhaust marks, do 2-4 applications..
    August 2003
Posted by tweety1 on Saturday, November 5, 2005 8:28 AM
I use smoke as the base for 99% of my weathering on a/c.
I tried pre shading panel lines like most people, but it never looked 'right' to me, then I tried post shading with Tamiya smoke through the airbrush and have never looked back since.
One thing to remember when using smoke for weatehring, it should be applied BEFORE you put on your flat coat, and when properly thinned it gives excellent results, and being a light tinted colour, you can apply the right amount of weathering/staining every single time.
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    January 2003
Posted by plasticmod992 on Sunday, November 6, 2005 9:42 PM
Yep, it can be sprayed. I thin it like my other Tamiya paints...1:1 with denatured alcohol. I've tried this to tint the exhaust cans of an aircraft model once, and the results were incredible. It cured to a nice semi-gloss sheen.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
