Stupid Question: problems with two moisture traps?
Posted by Anonymous on Tuesday, November 1, 2005 3:25 PM
See, I have the new Iwata TR2, which has a trigger. It comes with a pistol grip moisture trap - fights moisture, and makes a comfy handle.
BUT, I'm getting a regulator for my D500 compressor and it has a built in moisture trap.
So the question: with the two filters have any adverse effects on performance?
    May 2005
Posted by Bgrigg on Tuesday, November 1, 2005 4:00 PM
The only stupid question is "Are we there yet?" I mean, look out the windows kids! Does it look like we're there?
The two moisture traps will cancel each other out and actually create moisture.
No, I'm KIDDING, I'm a kidder! Tongue [:P]
You will probably not notice any difference, there may be a very slight drop in air pressure, but not enough to measure.
Remember the old saying:
"You can never be too thin, too rich, or have dry enough air."
So long folks!
    January 2004
Posted by MusicCity on Tuesday, November 1, 2005 6:57 PM
It shouldn't be a problem. I have two on my setup but I have a 140 psi compressor to work with to.
    May 2003
Posted by DrCemento on Wednesday, November 2, 2005 9:32 AM
I have a standard Reg/Trap coming out of the compressor and still had condensation in the line screw up my day! so I added an inline one closer to the Brush with no problems yet. I say the more the merrier, especially closer to the airbrush!
Model builder formerly posting as jbatesc6
Posted by Anonymous on Wednesday, November 2, 2005 10:13 AM
I agree with the above. Many professional rigs use two traps. One coming out of the compressor and one down line near the brush.
E
Posted by Anonymous on Wednesday, November 2, 2005 12:07 PM
Awesome, good to know. I gotta say, I'm a little curious about how much psi I've been using...I haven't a clue. I've just been using the...what's that thing called...bleeder valve like the instructions say. I'm interested in seeing the different effects that raising and lowering the pressure will yield. It's a small compressor though, so I might not notice a difference...
What do you guys use for typical use? (psi, I mean)
    May 2005
Posted by Bgrigg on Wednesday, November 2, 2005 12:26 PM
I spray between 10-15 psi, and clean at full bore. My little compressor only pumps out 40 psi tops. You probably wouldn't want to clean at any more than 50 psi.
So long folks!
Moderator
Posted by Matthew Usher on Wednesday, November 2, 2005 12:36 PM
I can't see any downside, and as a bonus, I believe you'll actually be able to airbrush underwater.
Kidding! Sorry, couldn't resist!
Matt @ FSM
Posted by Anonymous on Thursday, November 3, 2005 12:17 PM
Haa! That's it, I'm going to try it.
