Paint codes
Paint codes
Posted by Anonymous on Wednesday, November 2, 2005 3:53 PM
I was wondering if anyone has a chart with the Revell Paint codes along with the respective cross references such as Humbrol and model master. I found one such list based on the Humbrol paints, but not on the Revell paints. Could anyone steer me in the right direction?
    December 2003
Posted by 9x19mm on Thursday, November 3, 2005 6:13 AM
Here is a start http://www.ipmsstockholm.org/colorcharts/stuff_eng_colorcharts_humbrol.htm
Posted by Anonymous on Sunday, November 6, 2005 9:18 AM
That is the chart I came across. Unfortunately it is not based on the Revell codes. There are some in there, but not all. I am looking in particular for a chart that lists the Revell code number and color decription, then gives the corresponding "other" cross references. I am not sure if there even is one. Thanks for forwarding the link though...always a good reference.
    May 2005
Posted by Bgrigg on Sunday, November 6, 2005 9:30 AM
Give this one a try...
http://www.airmodel.sk/english/topcolor.html
So long folks!
    February 2005
Posted by Glamdring on Sunday, November 13, 2005 10:16 PM
What about Polly S colors?  The first link has them, but doesn't cross reference them.  The second doesn't even have them.
Since I have a list of tamiya colors I need, but my LHS only has Model Master and Polly S, and the Polly Scale paints are on sale this month ;D
Robert
"I can't get ahead no matter how hard I try, I'm gettin' really good at barely gettin' by"
    May 2005
Posted by Bgrigg on Sunday, November 13, 2005 10:58 PM
The IPMS Stockholm site does show the cross reference for Polly S to the FS series
http://www.ipmsstockholm.org/colorcharts/stuff_eng_colorcharts_fs.htm
I also found this on the IPMS USA site
You need to write to Floquil directly at: Floquil - Polly S Color Corp. 206 Milvan Dr., Weston Ontario M9L 1Z9, Canada
They have chip charts for all their colors, but they also have a "Military Color Reference Guide" with chips of their Rail, Military, and Marine (Naval) enamels plus 17 supplemental chapters cross-referencing the colors.
This guide is in an 8 1/2 x 11" 3-hole loose-leaf format and useful IMHO - for about $30.00. The individual chip charts will probably be about $3.00 to $5.00 each. You might also write Aeromaster for their enamel chips - their paints are made by Floquil and are chemically identical - and their chips come on the same sized paper and can be punched to fit in the same binder as the Floquil. You will then have a cross-reference to well over 300 distinct colors.
Good luck!
So long folks!
