D500 Compressor: Do need the bleeder valve with a regulator?
Posted by Anonymous on Tuesday, November 8, 2005 6:21 PM
Probably a stupid question...Anyway, I bought a paasche d500 compressor and it came with a bleeder valve. I assume that a bleeder valve takes the place of a regulator (in a really primative fashion) and that once you get a regulator you can do away with the bleeder valve.  BUT we all know what happens when you make an assumption, and the instructions for the compressor does say to never start the d500 without the bleeder valve...So I thought I'd consult the hive mind before I make a potentially expensive mistake.
What say ye, oh wise and powerful Oz? Can I chuck the bleeder?
    August 2005
Posted by Phil_H on Tuesday, November 8, 2005 7:06 PM
Keep the bleeder.
Near as I can tell, this is a diaphragm type compressor and has no storage tank.  When it's running, the air has to go somewhere.
Unless it's specifically designed for a diaphragm compressor all the regulator does is control the air flowing through it - it won't vent the excess air, which means that without the bleeder, you may rupture the diaphragm.
Posted by Anonymous on Thursday, November 10, 2005 9:02 AM
I see.  That's actually a little disheartening...that would mean that I've been running at full psi, and I've not been happy with the atomization.  I thought that the valve was regulating in some fashion.  Perhaps I just need to thin my paints more.
Do you think that the regulator would connect to the valve then? So: Compressor>bleeder>regulator? Or Compressor>regulator>valve?
Btw, yes, the D500 is a tankless diaphragm compressor
    August 2005
Posted by Phil_H on Thursday, November 10, 2005 5:12 PM
Compressor>bleeder>regulator - Yes, you could try it this way. With the bleeder on the "input" side of the reg,  whatever setting you have on the regulator should be accurate.
Compressor>regulator>valve     - This may work, but as the bleeder would be on the "output" side of the regulator, whatever pressure you have dialled into the regulator, you would lose some of it through the bleeder, so the actual pressure at the brush would be a bit lower.
Posted by Anonymous on Tuesday, November 15, 2005 8:00 AM
You know, now that I look at it because of the parts I have and the shape of the compressor, there only seems to be one way to hook it up, which is compressor>nipple adapter>regulator>bleeder>...
I've tried asking Paasche, but I can't get them to return my email. I don't want to damage the thing, but no where is it saying that the order matters. And the pictures that I've seen of the D500 that comes with the regulator already attached isn't showing a bleeder on it.
Does anyone have one of these compressors that can help?
