Omni 4000 Specs
Omni 4000 Specs
Posted by Anonymous on Wednesday, November 9, 2005 9:57 PM
Can someone tell me what the size of the nozzle/needle is?  I am currently using a Badger 155 and am wanting to get a gravity airbrush.  I have narrowed it down to the Iwata CR and the Omni 4000.  Will mostly be using it for 1/35 armor and 1/48 aircraft.  Thank you for any information you can give me.
V/R
Rob
    March 2004
Posted by bstrump on Wednesday, November 9, 2005 10:34 PM
You'll be more than happy with either of these brushes. I have the Omni but don't have a spec sheet for it but if I remember correctly, the nozzle comes in at 0.5mm.
Posted by Anonymous on Thursday, November 10, 2005 6:47 AM
Are both the Omni and Iwata capable doing fine lines?  I like the anthem 155 but seem to waste more paint.  My original brush was an Aztek but I didn't like the feel of the trigger.  Is the trigger pretty smooth on either of these brushes?
Rob
Posted by MikeV on Thursday, November 10, 2005 7:48 AM
The nozzle size is not what determines line width, it is the needle taper.
The Omni 4000 will spray as fine of a line as you will need for modeling in my opinion.
If you want even finer get the Badger 100LG or if you want the most precise get the Sotar.
Posted by Anonymous on Thursday, November 10, 2005 8:20 AM
Mike, could you expand on this? TIA
When I got my 100G (m) it sprayed badly.  I looked at the needle and the point was very rough almost with burs on the start of the taper.  I was too lazy to send it back and besides that I wanted to use it so I put it in a variable speed drill and polished it carefully with oil and 1200 sandpaper.  I was careful not to change the taper.  Overall it improved it.  Sorry for getting OT.
Posted by Anonymous on Thursday, November 10, 2005 11:29 AM
Is the trigger in the Omni 4000 smooth?  I haven't tested either of these brushes since I will be purhasing both online, but I have been to the local hobby store and the trigger on the Iwata seems smoother compared to my badger.  Thank you.
Rob
Posted by MikeV on Thursday, November 10, 2005 5:09 PM
Put some Badger Needle juice on the needle and trigger and it will be as smooth as you need.
Posted by MikeV on Thursday, November 10, 2005 5:11 PM
Sure. The more taper that a needle has the finer the line it can spray.
It is not the diameter of the nozzle that determines line width, it is how long and fast the taper of the needle is. Nozzle diameter is more a function of what medium it was designed to spray.
The really small nozzle sizes you read about were designed to spray finely pigmented mediums like urethanes, inks, etc. The bigger nozzles were designed for acrylics and such with larger pigments.
I hope this helps.
    July 2003
Posted by KJ200 on Tuesday, November 22, 2005 1:12 PM
Rob I use an Omni 4000 and a Badger 100, and hace to say I prefer the 100 as I find the trigger action smoother and more controllable than the Omni.
Don't get me wrong, the Omni is a great brush, I just feel more in control with the 100.
Karl
