Just picked up a Aztek 470-9 set
Posted by Anonymous on Friday, November 11, 2005 5:49 PM
Nice wooden case.... Scary looking airbrush, looks like a plastic model itself... Are these brushes safe for enamel and all that goes with it.. And why cant the bottle caps feeds be standardized?? Does any other manufactor bottle interchange??
    December 2003
Posted by thevinman on Friday, November 11, 2005 6:13 PM
The tips are safe for any solvents. The body is not, so don't soak it.
Posted by Anonymous on Friday, November 11, 2005 6:52 PM
is there any acutal metal inside there?? Almost want to crack it open to inspect... Well i might want to try it first.
    July 2004
Posted by tho9900 on Friday, November 11, 2005 7:06 PM
beyond springs and maybe a lever or two I don't think so... hmmm.. nevermind I forgot I gave away my old Aztek.. I was going to find out for you..  Wink [;)]
Posted by Anonymous on Friday, November 11, 2005 7:36 PM
Ahh well.... At least walmart  sells accessories for it!! What am I saying, i havent even figured out my badger 150 yet. I need to get to work!
    August 2004
Posted by Tankmaster7 on Friday, November 11, 2005 7:41 PM
aztek's are very very tempermental- don't get it mad. (mind you I've never been able to figure out what got it mad so I switched to my badger and iwata.)
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    March 2005
Posted by qtaylor on Friday, November 11, 2005 9:49 PM
I got mine really mad once.  Ended up with a build up of paint inside the plastic airline inside the brush.
I figured out how....don't be dumb enough to change nozzels with paint in the brush; figuring that if you held it so the nozzle was straight up that the paint won't fall out..  Dumb, dumb, dumb.  The paint not only falls back into the brush, but screwing the new nozzle on there ensures it stays there.
Ah well :)
QT
"Neither a purist nor a perfectionist be."
    December 2003
Posted by thevinman on Friday, November 11, 2005 10:32 PM
...same thing would happen if you pulled the needle on any internal mix AB, while you had a full cup of paint, wouldn't it?
    August 2004
Posted by Tankmaster7 on Monday, November 14, 2005 8:59 AM
Indeed it would, except they are all made so you can take them aprt and clean them if that happens.
    October 2005
Posted by usmc1371 on Monday, November 14, 2005 10:38 AM
I've been using the A470 for a few months now.  I only use Acryl paints.  I've found if I get paint inside the airbrush, I just run it under water until the water coming out is clear.  No problems.  I don't know what to do if I start airbrushing enamels though.
Jesse
    April 2005
Posted by cruichin on Monday, November 14, 2005 11:39 AM
Do you put it under water while you spray? Sounds novel. I have dipped mine in windshield washer fluid and then sprayed into the waste collector.
Posted by ABARNE on Monday, November 14, 2005 2:26 PM
Don't crack it open, because you'll void the warranty.  But if you're curious as to what's inside, see the following:
http://www.master194.com/maquettes/autres/aztec.htm
Because of my experience with my A430(and countless others who have shared the same) , I always recommend against buying Azteks.  On the other hand, since you already have the thing, you might as well give it a whirl, and see how you like it.
Posted by Anonymous on Monday, November 14, 2005 5:20 PM
I've used an Aztec airbrush for ages now with no problems. I have sprayed acrylics and enamels through it and it's ok. Haven't used laquers as I have no real use for them unlike others perhaps.
The tips are impervious to paint thinners but as has been stated the body is not.
To clean the brush, remove the paint bottle and spray until it stops. Put a bottle of solvent through and spray until clear. I tend to spray and remove the bottle from time to time.
Testors says the tips can't be taken apart but they can and I do on occasion. Others just drop the tips into the appropriate solvent. Doesn't seem to harm them.
The body can't be taken apart as this voids the lifetime warranty on the body.
I had a problem with the body only once and it was replaced by the representative with no hassles at all. Wish all my warranty problems were handled as easy as this was.
For the price, it is not a bad brush. It does what I want and that's what counts. A more expensive brush would do the same thing as the Aztec but why pay more money than you have to?
    October 2005
Posted by usmc1371 on Monday, November 14, 2005 6:03 PM
Sometimes, when I clean the airbrush, I'll run the airbrush under the facet until no paint comes out.  Then I shake all the excess water out the the body.  Good as new.
Jesse
Posted by echolmberg on Wednesday, November 16, 2005 7:27 AM
I totally agree with what Lancaster has to say.  I've used my Aztek for years now and not once have I ever had a single problem with it.  The tips work fine for me.  I keep everything clean and she just keeps on going.  Clean up is a snap.  I use that red plastic tool to clean out any paint which may have gotten inside the area where the tip screws in.  Otherwise, whenever I'm done using the airbrush I just take a piece of paper toweling dipped in thinner and use that to clean out that area.  People like to badmouth the Azteks and I just don't know why.  User error?
Eric
    April 2005
Posted by cruichin on Wednesday, November 16, 2005 1:49 PM
I've had two of the tips clog completely. Only ran acrylics through them, and cleaned thoroughly. I left them in a bath of windshield wiper fluid for over a week, but still could not unclog them. Very frustrating!
    December 2003
Posted by thevinman on Wednesday, November 16, 2005 1:51 PM
You need to pull the tips apart to get them cleaned good. It takes 2 seconds.
Posted by Anonymous on Thursday, November 17, 2005 12:33 PM
wow super link! Thanks!
