How to temporarily hold open canopy closed while painting rest of plane?
    March 2005
Posted by qtaylor on Friday, November 11, 2005 9:52 PM
I've been thinking this over.  The best way to fill the big hole of the open canopy is to set it in place...as if it was closed.  Now, how to seal it to keep the airbrush out of the cockpit?  White glue, blue-tak?
Ideas?
QT
"Neither a purist nor a perfectionist be."
    March 2004
Posted by bstrump on Friday, November 11, 2005 9:59 PM
I've used Micro Kristal Kleer when I wanted to do this but the white glue will work just as well. In fact, I even use it when I want to keep the canopy permanently closed. It's surprisingly strong.
    May 2005
Posted by Bgrigg on Friday, November 11, 2005 11:16 PM
I stuff the cockpit with wet paper towels (wrung out of course). Paint away, and then when the paint is dry, re-wet the towels and pull them out.
So long folks!
    March 2005
Posted by qtaylor on Saturday, November 12, 2005 6:42 AM
OOooohh...the wet paper towel idea is an interesting one.  When you do that, you leave the canopy off?
QT
    July 2004
Posted by tho9900 on Saturday, November 12, 2005 8:24 AM
yup!  the thing is though if you are doing a camo pattern it's usually better to put the canopy on if the camo will stretch over it... otherwise the paper towel thing works...
    May 2003
Posted by qmiester on Saturday, November 12, 2005 9:52 AM
I also use the paper towel or tissue paper(Kleenix).  Dampen lightly and carefully fill the area you want to protect (I've found a set of curved tweezers work better than your fingers). I dampen the paper again just before I paint and again just before I remove it.  Also works great for wheel wells and openings in the cowling.
Quincy
