Problem with Iwata thread & the airhose
Posted by Anonymous on Sunday, November 13, 2005 7:48 AM
I've just bought an iwata Revolution CR AB and a Medea BT010 air hose.
The first hose I got I could only make one 360 degree turn - i.e. the airhose only got as far as the first thread on the AB.
I returned the hose and got it replaced. This one I got about half way up the AB's thread before I couldn't screw it any tighter.
I suspect that the problem is the thread on the AB.
Has anyone else experienced this? I seem to be the only person on here who has not (so far) had a positive experience with Iwata.
    July 2004
Posted by tho9900 on Sunday, November 13, 2005 8:10 AM
I just looked at my Iwata and mine doesn't screw entirely up the threads either... try pressuring up the hose and see if there is a leak.  This is probably normal.. (the fact it only goes halfway up or so)
Posted by Anonymous on Sunday, November 13, 2005 8:57 AM
Thanks!
My Paasche threads up all the way, so i presumed the Iwata was the same. I hadn't tried it out in case I had to return it.
    July 2004
Posted by tho9900 on Sunday, November 13, 2005 1:54 PM
after fiddling with mine I realized it goes a bit more than halfway up.  When you posted the question I went and took the pistol grip water trap off the brush and screwed it directly on the brush.  Some teflon tape was still on the threads and kept it from going all the way.  BUT after removing the offending teflon tape I still had about 3 threads showing when fully sealed.  So you are probably ok as long as it doesn't leak when you pressure up.
Good luck!
