badger 175 and acrylics
    October 2005
Posted by looper on Sunday, November 13, 2005 9:34 AM
hi everyone, i have a badger 175 with the 3 tips and was wondering if it's bad to shoot straight acrylics through it without thinning. last night i was painting the chassis of my 65 impala with thinned MM flat black and kept getting watery results, so i turned up the psi and shot it straight...got great results. the only problem was when i was trying to shoot some distilled water after the painting was done, i got some bubbles in the metal cup. that was with the medium accessories, should i use the large ones instead? thanks
Andy
    May 2005
Posted by Bgrigg on Sunday, November 13, 2005 10:06 AM
It's not bad but you will likely have difficulties at some point. All paint have pigments that may eventually clog up the nozzle. Thinning is recommended. Remember that you don't have to thin so much that the color changes! I usually thin 3:1. MusicCity has a great deal of information on acrylic paints and thinning on his website.
The bubbles indicate that the air couldn't get through the nozzle, and took the path of least resistance.
The large nozzle and needle will probably let the unthinned paint through but at the cost of detail work. I have a 150 with a medium nozzle and have great results with acyrlic paints, in my case Tamiya. I find the Model Master Acryl line to be "watery" in the first place.
So long folks!
    July 2004
Posted by tho9900 on Sunday, November 13, 2005 10:07 AM
I have the 175 and you should thin your acrylics and use the med nozzle/needle/head.  Typically you should thin about 3:2 or so, play with it until you get the mix that is right for you.  If your paint doesn't cover on the first pass let it dry and go for another pass.  Sometimes it takes a few coats especially with colors like yellow and white.  If you mean watery as in it was spider legging (where you shot the paint had little runners wiggling out from the edges) you are either thinning too much or shooting with too high of a pressure.  With my 175 about 16 to 20 psi was great for full coverage and 14-16 worked ok for smaller detail.
It sounds like there is dried paint in the head assembly.  You should remove the head and nozzle and soak them in laqcuer thinner for 30 min or so.  swirling the cup every once in awhile to help get the old paint loose.  Then use a microbrush or toothpick to gently pick out the rest of the paint if any.  This should have you up and running in no time.  If you haven't, take out the needle and clean it gently as well.
    October 2005
Posted by looper on Sunday, November 13, 2005 10:54 AM
thanks for the replies guys. when i used the regular testor acrylic to paint the body i thinned it and had no problems. i sprayed the underside of  the chassis with the thinned MM 3 times and the paint would not stick properly. by watery i mean the paint doesn't stick and puddles up. when i shot it straight it covered in 1 pass, both the underside which had been sprayed 3 times and the topside which hadn't been sprayed at all. i was using a 3:1.5 ratio, i'll try it again today by using less water. what is the teflon bearing that the manual talks about? i'm worried about soaking the wrong part in lacuer thinner and messing up the AB. thanks again guys, i really appreciate the help.
Andy
    June 2005
Posted by smokinguns3 on Sunday, November 13, 2005 12:28 PM
Ive got a badger 175 to some acyrlics i thin and they work well and some i dont. If i get some cloging in the tip i put a little model masters acrylic thinner in the mix and i mean a little around 2 to 3 drops in my color cup. to me it seams like the model masters RLM color dont need to be thined but may be its just the batch of paint i got.
Rob I think i can I think i can
    July 2004
Posted by tho9900 on Sunday, November 13, 2005 2:03 PM
The teflon bearing is embedded in the body of the airbrush... you don't want to soak the body in laqcuer thinner.  All you do is unscrew the two cones making up the head, then unscrew the nozzle out of the body.  Put those three things in a little shot glass or something and cover them with laqcuer thinner.  Let soak, clean, then put them back on.
If the paint was puddling and not sticking your plastic might have oils on it.  I always wash my models with a little mild dishwashing liquid and water, or wipe down with alcohol before painting.  With acrylics a little oil can put a damper on your painting fun!  The molding process has oils that remain on the surface of the plastic, plus handling it puts fingerprints on it which have oil in them.  Wash them off and I think you should have no problems next time!
Good luck!
    October 2005
Posted by usmc1371 on Monday, November 14, 2005 10:40 AM
Most Model Master Acryl paints do not need to be thinned for airbrushing.  They are designed that way. This is from Testors FAQ's:
Question:  What is ACRYL?
Answer:  Testor has introduced a new formula of Model Master “Acryl” paints. This line of acrylic, water-based formula is certified non-toxic, non-flammable and has a very low VOC level. The paints dry fast and clean up easily. Model Master “Acryl” has fantastic leveling properties so brush strokes virtually disappear, and it doesn’t pull away from details. Once dry, the “Acryl” paints develop a hard, durable enamel-like finish, which is buffable, waxable, washable, and can be wet-sanded. This new paint features the most popular high gloss and flat finish colors from the Model Master enamel line. All colors, except Figure Model Paints which feature thicker viscosity for better brushing, are airbrushable directly from the bottle-no thinning necessary (some flats may need thinning when spraying fine lines). All paints are packaged in 1/2oz. bottles. The entire line of Model Master Acryl paints has been proven effective through extensive testing by both novices and pros for over a year.
Jesse
    December 2003
Posted by thevinman on Monday, November 14, 2005 11:16 AM
I would take almost everything the Mfg's say with a grain of salt. Some folks may not need to thin, but it all depends on your setup/style of airbrushing.
If I was testors, I would "spin" these paints as not needing thinning to get an edge.
    May 2005
Posted by Bgrigg on Monday, November 14, 2005 11:53 AM
That would explain why I think they're watery!
So long folks!
    December 2003
Posted by thevinman on Monday, November 14, 2005 12:01 PM
Leave it to testors to "water-down" thier paints and then charge you for it! Seems like a marketing scheme to me! Big Smile [:D]
Posted by MikeV on Monday, November 14, 2005 6:48 PM
Good luck!
Lacquer will not affect the Teflon bearing
It is the rubber O ring in the air valve that you have to be careful of.
    July 2004
Posted by tho9900 on Monday, November 14, 2005 8:17 PM
Good luck!
right....  I was just telling him soaking the body in lacquer thinner wasn't a good idea.  Mayhem may occur Wink [;)]
    October 2005
Posted by usmc1371 on Tuesday, November 15, 2005 9:43 AM
Personally, I love the Acryl paints.  I never have to thin them to airbrush, just pour and spray.  Their brushing qualities are excellent also.  And they work great for weathering, such as washes and dry brushing.  Just be sure to use Model Master Acryl Thinner.
Jesse
    October 2005
Posted by looper on Tuesday, November 15, 2005 1:09 PM
hey guys thanks to all that replied, great info!!. i've been spraying it straight and i got great results so far. i don't have MM thinner though so i do get some paint buildup on the nozzle. ok the teflon bearing will go bad at one time or another and i have to send the AB in to get it replaced, but it won't get damaged by solvents. the rubber o-ring that keeps air from leaking into the AB before you push the trigger will though. i think i'm getting the hang of this airbrushing thing !!!!! Big Smile [:D]
Andy
    February 2004
Posted by RichardI on Tuesday, November 15, 2005 2:10 PM
looper: I use acrylic paints and I have found that one drop of retarder (I use Createx but there are other brands - sometimes called extenders) per metal cup of paint makes all the difference in the world. One of the problems with acrylics is that they dry too fast. That could be why you're seeing that problem. The retarder adds to the drying time, allowing the paint to act very close to an enamel in terms of flow. And, it makes your airbrush much easier to clean.
Rich Cool [8D]
On the bench: 1/48 Revell PBY Catalina 0A-10A. Next up: Moebius 1/24 Chariot from Lost in Space.
    December 2004
Posted by Hippy-Ed on Tuesday, May 30, 2006 7:23 PM
You make it sound so simple TomWink [;)]Laugh [(-D]
If you lose your sense of humor, you've lost everything
Posted by MikeV on Tuesday, May 30, 2006 7:32 PM
Jesse
I have found Tamiya to be superior to Acryl.
I tried Acryl and used everything I could to get it to work and it did not cooperate so it is history now.
    October 2005
Posted by usmc1371 on Wednesday, May 31, 2006 8:24 PM
Hey Mike,
Just curious, what wasn't working for you?  I actually had to stop using the Acryl because it was giving me headaches.  Weird huh?  I use a spray booth, vent outside and use a 3 stage respirator.  Still got headaches.  Other than that, I really like the acryl and had no problems.
Jesse
Posted by MikeV on Wednesday, May 31, 2006 8:35 PM
Jesse,
It did not adhere as well as Tamiya and it was much harder to clean up.
They put a binder in Acryl to make it adhere more and it sticks to the airbrush cup like glue.
    December 2004
Posted by Hippy-Ed on Wednesday, May 31, 2006 8:42 PM
This is interesting Mike, I have a few Acryls in my stash which I'll be using pretty soon.Sad [:(] I can't afford to go out & order new paints so, what can I do about this?
Posted by MikeV on Wednesday, May 31, 2006 9:37 PM
Ed,
Prime the surface or scuff it with a Scotchbrite pad or 800 grit sandpaper before painting and remove any oils from the outside of the model with Iso alcohol or something similar on the bare plastic before painting. This should be done with all acrylics as they all have a tendency to not adhere well due to their nature.
I painted my A-1 Skyraider and my F-15E both with Acryl and they came out fairly well but I had problems with both in terms of the finish being not as smooth as I like.
    December 2004
Posted by Hippy-Ed on Wednesday, May 31, 2006 9:48 PM
Thanks Mike. I have been making it a habit to wash down  my models with alcohol before painting as it's been mentioned plenty of times here in the forums. I'll try the scuffing when I use my Acryls. ThanksThumbs Up [tup]
Posted by MikeV on Wednesday, May 31, 2006 10:01 PM
It is also a good idea to wear some white cotton gloves or such to keep fingerprints off the model while handling it during painting, etc.
Cleaning it with Plastic Prep or alcohol and then handling it with oily skin is not a good thing.
I am guilty of that for sure. Big Smile [:D]
    December 2004
Posted by Hippy-Ed on Wednesday, May 31, 2006 10:33 PM
Especially when trying to paintLoL Mike!! Who isn't guilty of that Felony?!Big Smile [:D] I do not have cotton gloves but, due to my status as a care giver for my g.f. I have a supply of Latex gloves & I use them all the time for modelingSmile [:)] Usually on the hand that I'm holding the item to be painted. I seem to dislike a glove on my trigger fingerWink [;)]
Posted by Anonymous on Thursday, June 1, 2006 6:40 PM
Ed, I agree with Mike about Acryl. My two cents are to work very quickly so that it won't start to set up in the brush or cup/jar. Retarder helps with this, but if it dries in the brush, You'll probably end up soaking in lacquer thinner to get it all out. PollyScale is gentler but many people swear by Tamiya and Vallejo.
E
    December 2004
Posted by Hippy-Ed on Thursday, June 1, 2006 8:13 PM
E
I appreciate this inputSmile [:)] The Retarder (my brother?Evil [}:)]) would I find this at let's say Michael's Art store perhaps?
I've been checking out the threads on Vallejo paints & it does kinda peak my interest in it.
Posted by Anonymous on Thursday, June 1, 2006 8:22 PM
Look through Tom's posts on this subject. He is the house expert on Vallejo.
E
    December 2004
Posted by Hippy-Ed on Thursday, June 1, 2006 9:01 PM
E
Roger that.  I will do thatThumbs Up [tup]  I could always get 'im on the direct email tooBig Smile [:D]
