hud wrote: |
Thanks for your reply. You've got my curiosity up with a couple of things you mentioned. I must be missing the boat on drying times. It takes me three days, sometimes longer, to do a three color paint job and a coat of Future for decal apps using acrylic, and then I still hold my breath for good results. |
High humidity may well have an effect. I live in San Diego, and although I'm within a couple of miles from the ocean, it's still pretty dry here. To give an idea, I've heard of people who have to regularly drain their moisture traps, whereas where I live, I might a bit of moisture after a painting session, but I don't think I've ever collected enough water to flow out the screw valvel in the bottom of the thing.
hud wrote: |
Also, I understand that the entire model is not covered with decals but I still give the entire model a coat or more of Future/gloss. Is it common pratice to just gloss the areas where the decals are to be applied and if so wouldn't the builder still have to wait the same amount of time regardless of whether all or part of the model has been decal prepped? |
I too will gloss the entire model. I have heard of people doing spot glossing, but my fear has been that you would have an uneven finish and see where the gloss had been. Obviously by glossing the whole thing, any effects that the gloss has on the finish are uniform. I also will add a gloss coat over the decals prior to the flat coat, again to try for uniformity
hud wrote: |
Do you use an airbrush? I can see adding color after color if you're brush painting but not , by my method, with an airbrush. |
Indeed I do, Badger 200NH single action for enamels and a Paasche H single action for acrylics. Using an airbrush is another reason for the rapid drying times because the coat of paint it lays down is so much thinner than a brush painted coat. Prior to owning an airbrush, I think I had to usually wait at least overnight for one coat to be cured enough to paint another on top.
hud wrote: |
FWIW, I still wish they made all paints in both gloss and flat but I'll probably never get that wish :) Just curious and always looking for better techniques. Any suggestions? |
I think experimenting with new techniques is one of the things that makes this hobby so darn fascinating. Here's an off the wall experiment. Try mixing some flat enamel with clear gloss enamel. Floquil makes a product called Crystal Cote. You might have to play with the ratios. Even then, it might not cover or if it covers, it might not be glossy. Or who knows, it might work and give you gloss paint.
Andy
