well you can leave it awhile on the canopy without worrying, I would wait until AFTER the final dull coat to remove it..
I have had mine on as much as 7 days or so and although it seemed to leave a residue, washing with soap and water got it all off... just plain old hand soap from the dispenser.
I just take a toothpick and gently nudge at the corners of the BMF, you'll get it to where it starts bunching up then you can use the toothpick to get under it and just pull straight up towards you from there, if you push it all the way across the clear plastic it might leave scratches.
Good luck!!!
