Does anyone here have the Iwata Sprint Jet compressor?
Posted by ipms40049 on Saturday, November 19, 2005 4:07 AM
If so, I have a question. Is their air suppose to be coming out of the bottom of the  Moisture trap filter thing?
seems I have air coming out of that valve, the one you turn to raise and lower the pressure.
Pat Hensley Booneville, Ms "Thank you for being here and playing nice"...please do not drag sand outside the box ! CURRENT BUILD(s) Revell 1/72 U Boat VII C Tamiya Willys Jeep - for 2010 Nats Bronco's Staghound -for 2010 Nats Dragons M16 Multi gun carriage - for the 2020 Nats. LOL
    December 2003
Posted by cbreeze on Monday, November 21, 2005 7:48 PM
Greetings,
I have the Iwata Smart Jet which is the Sprint Jet with the auto shutoff.  When I bought my Smart Jet, it had the type of regulator/moisture trap that you are questioning.  What you have and I had, is not a true regulator.  I believe it is an air bleed regulator and the air leak you are concerned about is normal for that type of regulator.  Twisting that screw is how you regulate the pressure.  I called Coast Airbrush and ordered a true regulator for my Smart Jet.  It screws right on to the moisture trap and works much better.
Hope this helps you,
Chuck B.
Posted by ipms40049 on Friday, November 25, 2005 6:48 AM
 cbreeze wrote:
  Thanks alot Chuck!!!
Greetings,
Chuck B.
