Anyone use Microgloss/MicroFlat by Microscale?
Posted by Anonymous on Friday, November 25, 2005 12:35 PM
Hi all, I'm new to forum and I'm planning on building my first model in 4 years.
I'm still a novice at this having only build 3 in the past with less that stellar results.
Anyway, after investing money in some proper tools and reading countless articles such as those on this forum, I'm hoping this model will be my best.
I'm trying to settle on a gloss/flat coat for decalling and sealing the paint job.
I'm planning on using Tamiya acrylics and was wondering if anyone has used MicroGloss/MicroFlat?
I've read about Future and mixing it with the flat base, but I'm a little hesitant to use it because of reports of it yellowing over time. The MicroGloss/Flat bottles clearly state its a "non-yellowing" finish. Has anyone used these? I don't have an airbrush so i'll be brushing them on.
Any help is greatly appreciated,
Cheers,
Dan
    March 2004
Posted by bstrump on Saturday, November 26, 2005 8:42 PM
I used the MicroGloss/Flat religiously for years until I recently switched to Testors Acryl Flat and it is excellent paint to work with. The thing is, I used it with an airbrush so I'm not sure how it'll work brushed on by hand. I guess as long as you thin it down and apply in thin coats, you should be fine. This is especially true with the flat as applying too much too soon can lead to white chalky spots forming. BTW,Sign - Welcome [#welcome]to the Forum.
Posted by Anonymous on Tuesday, November 29, 2005 9:06 AM
microgloss worked fine for me but microflat wasn't really flat at all.  this was brushed on btw.  i like polyscale acrylic gloss and flat coats.  i spray them directly out of the bottle or brush them on.  the gloss is glossy and the flat is actually flat.  no problems so far.
Posted by ABARNE on Tuesday, November 29, 2005 2:30 PM
Like GoatMonkey, I used MicroFlat and did not find it to be particularly flat.  It seemed to be somehwere between a satin and a semi-gloss.  On the bright side, I found that I could mix it with ground pastel chalk to make a pretty decent mud for armored vehicles.
I tried Testors Gloss and DullCoat lacquers but wasn't totally happy with either.  I found it difficult to to lay down a smooth gloss coat.  The dull coat had a tendency to have batch to batch variation in flatness, sometimes flat and sometimes satin.
I currently use Future for gloss coats and Future/Tamiya X-21 Flat Base(4 parts Future to 1 part Flat Base) and have been quite happy with the results.  I haven't used it long enough to speak from experience about any yellowing effects, but from the concensus of what I have read on the subject, I am not worried about it.
Andy
Posted by Anonymous on Tuesday, November 29, 2005 7:55 PM
Thanks for the replies guys! Smile [:)] much appreciated.
I'll look into pollyscale, otherwise I guess I'll just use future.
    January 2003
Posted by plasticmod992 on Tuesday, November 29, 2005 10:02 PM
Welcome to the forum!
I have used Microscale clear finishes with no real problems years ago.  I applied them with a wide #12 Shader brush.  To minimize brush strokes, I thinned them with distilled water per their instructions.  I know you mentioned you'll be brushing them on for now, until, I'm assuming you later purchase an airbrush.  Now-a-days, I still use Microscale for some models, however I airbrush them with a very inexpensive Paasche-H single action airbrush.  As a future reference, the Paasche-H can be had at several online web stores, such as; Dixie Art & Airbrush Suppliy Store, www.dixieart.com .  Bear Air, www.bearair.com .  Good luck and welcome back to the hobby!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by Anonymous on Thursday, December 1, 2005 8:12 AM
I used Testors dullcoat for a while and the finish itself wasn't bad but the lacquer had a tendency to melt the acrilyc paint.  After one time where a fine misting of paint for dust got washed down to the bottom of all the vertical surfaces forming what looked like sludge, i pretty much quit on that one.  I'm sure it'd work much better if you used many lighter coats instead of dumping the whole can on the thing like i do but you don't have to be that careful with something like polyscale flat and that's why i like it.
Posted by Anonymous on Friday, December 2, 2005 11:15 AM
I've used them extensively and have allways gotten exquisit results.  MicroGloss over matt paints for decaling, then MicroFlat to seal the whole thing.  I've used them with a brush and with an airbrush and they work very well with either and are very forgiving either way.  As mentioned the flat is not totaly matt but I actually like the very slight velvet finish it gives.
    May 2003
Posted by qmiester on Wednesday, December 7, 2005 3:51 PM
I used them for years until I noticed the older models (5+ years old that is) were noticably yellowing. Switched to Future and MM enamel semi-gloss and dullcote and haven't noticed the yellowing problem since.
Quincy
Posted by Anonymous on Wednesday, December 7, 2005 11:35 PM
Interesting, even though the bottle says 'non-yellowing'?
Thanks alot for the info! I guess I'll give the Future, Future/Tamiya Flat treatment a try.
Posted by Anonymous on Saturday, December 10, 2005 8:13 PM
i just used microflat on my moogle figure and the stuff cracked up big time.  think that's the end of me using THAT...  going to go see if i can smooth it out with some water or something...
update:  nope, smooth it out with water and it just cracks back up...  time to strip the paint and start the paint from scratch!
Posted by Anonymous on Sunday, December 11, 2005 10:32 AM
Sorry to hear that goatmonkey, but thanks for passing on that info.
I plan to give Future/Tamiya Flat a try. I'm also gonna try to mix Tamiya Clear/Tamiya Flat (haven't seen too many people use this combination) - it should give me a flat clear coat, shouldn't it?
we'll see how it goes.
Cheers
