Most Model Master Acryl paints do not need to be thinned for airbrushing. They are designed that way. This is from Testors FAQ's:
Question: |
What is ACRYL? |
Answer: |
Testor has introduced a new formula of Model Master “Acryl” paints. This line of acrylic, water-based formula is certified non-toxic, non-flammable and has a very low VOC level. The paints dry fast and clean up easily. Model Master “Acryl” has fantastic leveling properties so brush strokes virtually disappear, and it doesn’t pull away from details. Once dry, the “Acryl” paints develop a hard, durable enamel-like finish, which is buffable, waxable, washable, and can be wet-sanded. This new paint features the most popular high gloss and flat finish colors from the Model Master enamel line. All colors, except Figure Model Paints which feature thicker viscosity for better brushing, are airbrushable directly from the bottle-no thinning necessary (some flats may need thinning when spraying fine lines). All paints are packaged in 1/2oz. bottles. The entire line of Model Master Acryl paints has been proven effective through extensive testing by both novices and pros for over a year. |
