how can i make a reservoir tank?
    February 2016
Posted by duckman on Wednesday, November 30, 2005 1:09 AM
i have the testors blue mini diaphragm comperssor and im using a Paasche double action VL airbrush for along time ive been wanting a compressor with a reservoir tank because of the steady airflow.
so i was wonding if i was to make a air storage tank what would be the best way to do this
i already have the idea of: Compressor_-_short hose_-_Reservoir tank_-_Hose Airbrush= Happy!
im aware that the tank wouldnt have alot of psi in it because the compressors not exactly strong but my friend at the LHS said it would be a good idea!
On The Bench:
Revell- 1/72 Messerschmitt Me P1099
Posted by Anonymous on Wednesday, November 30, 2005 7:52 AM
Your idea is fine you should run with it.  Another option, which many have mentioned before in this forum, is just use extra hose to act the same as a resevoir tank.  Here is a link from Harbor freight.  These things hold a good bit of air.  They have them at lowes or homedepot also I think.  You might need some fittings for the ends too.
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=54075
