acrylics
acrylics
Posted by GianMan on Tuesday, December 6, 2005 3:13 PM
well i was just thinking   i have been using enamels for every model that i have done and i am about to start a new one    are acrylics better   or easier to use   i would just like the clean up probably  and if i do switch how do i clean and thin for airbrushing  water
thanks
    December 2003
Posted by thevinman on Tuesday, December 6, 2005 4:33 PM
Check out this article:
http://www.craigcentral.com/models/paint.asp
I use acrlyics...but it all depends on what your needs are. Each has advantages & disadvantages.
    May 2005
Posted by Bgrigg on Tuesday, December 6, 2005 4:37 PM
I'm on the acrylic bandwagon, too. Easy to clean, less smell, tad tempermental at times, but in all good results and you clean up with water and windex!
So long folks!
    July 2004
Posted by tho9900 on Tuesday, December 6, 2005 5:48 PM
same here... I use about 90% acrylics when painting.  When handbrushing sometimes I use enamels, but the acrylics I use (MM, Vallejo made "Color of Eagles" and Boyds) all handbrush just as well as enamel.  and ditto on Bills comment on being easier to clean and no smell...  It was a bit of a learning curve learning to spray the correctly (nothing horrible, just readjusting pressures and thinning and the sort) but all in all I find it easier now with acrylics....
Posted by GianMan on Tuesday, December 6, 2005 6:18 PM
well thanks for the help but could i ask one more question.    can u mix the two paints? like could u use acrylics and enamels on  the same model or do they affect eachother cause i know alot of the clears i use can be used over both
thanks again
    December 2003
Posted by thevinman on Tuesday, December 6, 2005 6:46 PM
Yes, you can use both, but be careful. Enamels are "hotter" (read: stronger solvent) than acrylics. If you spray enamel over uncured acrylics, or spray a heavy coat of enamel over acrylic, the enamel might eat away the acrylic base coat.
    October 2003
Posted by f-4phantom on Tuesday, December 6, 2005 6:57 PM
I love acrylics. The most important rule to follow with them is use a primer. It gives the acrylic a good surface to stick to.
Posted by Anonymous on Wednesday, December 7, 2005 4:29 AM
I made the switch to acrylics about a year ago in my AB anyway and I havent regretted it.  I use Tamiya exclusively and I am getting better at mixing paint if they dont have it available.  I still brush with enamel though.
    January 2004
Posted by MusicCity on Wednesday, December 7, 2005 5:57 AM
Acrylics for me as well.  About the only time I use enamel or laquer these days is for a primer or for metallizers.
Posted by waikong on Wednesday, December 7, 2005 11:48 AM
Another vote for Acrylic, I'm sure its better for my health long term (but I still wear a mask).
I mix acrylic & Enamel all the time as I use a enmal primer, or sometimes I use enamel spray can to cover large monochrome areas.
Posted by Anonymous on Friday, December 9, 2005 6:53 PM
I got a couple questions, Is it true you can just use acrylics straight out of the bottle when useing an airbrush? And can you thin ALL acrylics with water or just some?
    July 2004
Posted by tho9900 on Friday, December 9, 2005 7:01 PM
Rob - a some of them can be shot straight out of the bottle, Vallejo Model Air, Color of Eagles and some MM Acryl paints to name a few.  Others like Tamiya need thinning.
As far as thinning with water, I know Vallejo, Color of Eagles and I believe Gunze can be thinned with water, while MM, Boyds and Tamiya have an alcohol based thinner (you can even use 91% isopropyl from the drug store to thin them. Can't comment on the others though...
    December 2003
Posted by thevinman on Friday, December 9, 2005 7:03 PM
Some...but it really depends a bunch of other factors when you are airbrushing. The viscosity of the paint, is just one factor. You also need to be aware of pressure, distance from the model, needle size (if applicable)...among other things.
No. Just some. But, acrylics tend to dry fast, so I would use an acrylic thinner made specifically for your paint. They are made for the job and usually have a "retarder" mixed in. I spend too many hours on my models to skimp on thinner.
