Say all, I have been using Tamiya acrylic with great results for the past year. Some may remember my 1/72nd scale T-45A Goshawk and F/A-18E posted on the Aircraft Forum, both painted entirely with Tamiya! Coundn't be more pleased with them. However, I have been a Testors Model Master fan since I cut my teeth into this hobby many, many moons ago. I even got excellent results from their "old formula" acrylics..who knew?! Specifically, I just love the notion of going to the paint rack, grabbing the specific FS colors I need, without having to mix the Tamiya. Also, like their enamels, the Testors MM Acryl line has all the FS colors I need for my modern jet color schemes. The only problem is; I haven't, until reading this exciting post, been sucessfull with the MM Acryl, thinning for finelines. Excited about Scott's results, I have already broke out the Tamiya thinner and I'm planning a trip to the LHS for some MM Acryl to try it out. But before I do, has ayone tried this method to thin Acryl for fine line spraying? I'm an acomplished airbrusher, used just about every acrylic on the market with great results..except "MM Acryl." If I can get Acryl to spray "sustained" finelines with minimal tip-dry, pre-mature trying in the color cup, easier cleaning...I will be in modeling utopia! OK, thats taking it a little too far...sorry.
PS: Previous thinners and results when used with MM Acryl with poor results:
1. MM Acryl's own brand thinner
*Emmediate and constant tip-dry. Paint dries rapidly, even in covered airbrush colorcup after thinning. Sprays a fineline for a few secounds, then ol' "Murphy Law" kicks in agian with the tip dry at the critical moment during spraying....nice..
2. Water (distiled)/ Alcohol mix + retarder
*Same rsults as previous with more rapid tip-dry, paint rapidly drying in airbrush.
3. Straight distilled water
*Profanity, anger, frustration, use of an alcoholic beverage needed..."Radio Edit"
4. Windex
*Poor adhesion, gritty, pebbely finish (various thinning ratios used), same results as #3. All the above.
Greg Williams
Owner/ Manager
Modern Hobbies LLC
Indianapolis, IN.
IPMS #44084
