Splicing hoses
Splicing hoses
Posted by Anonymous on Thursday, December 15, 2005 11:08 PM
I have an airbrush and I need to attack a moisture trap to it, the problem is that It has a braided hose and I have no idea how to properly cut and add a moisture trap to one, the hose and moisture trap are both Paasche. Any help?
Posted by ckfredrickson on Friday, December 16, 2005 1:44 PM
I had the same concerns when I had to cut my hose to insert the water trap (both Badger), but trust me... it's not that difficult.
Step 1: cut the hose; I used scissors but I suppose a sharp knife would do just as well.  You want the cut far enough from the compressor that the water has a chance to condense, but not so close to the brush that it will interfere with painting: 18-24" from the hose-airbrush connection is usually recommended.
Step 2.  Put one nut on each half of the hose so that the threads face the cut edges.
Step 3.  Insert the nipples on the water trap into the hose (I don't remember if it has to go on in a certain direction, so check to see if there are any arrows or notations (i.e. air-->)).  Use the nuts to tighten the hose against the nipple.  You're done.
Hope this answers your questions, and good luck.
    August 2005
Posted by eizzle on Friday, December 16, 2005 4:15 PM
Can you just put the water trap on like this. Compressor to a 1/4" NPT male fitting, water trap, then a quick connect fitting or another 1/4" NPT male fitting, then your airbrush hose? Just thinking this might save you from having to cut up a hose and still get the same results.
Colin
 Homer Simpson for president!!!
Posted by Anonymous on Friday, December 16, 2005 6:11 PM
thats not a bad idea but like ckfredrickson wrote, it needs to be a certain legth away from the compressor to give the water a chance to condense.
Posted by ckfredrickson on Friday, December 16, 2005 8:46 PM
Eizzle - Another issue is that the moisture trap being considered by Rob J is specifically meant to be placed in line... moisture traps can be spliced in via an NPT fitting, but it's much easier to buy one designed for that purpose (i.e. at Home Depot or Lowes) than try to adapt an in-line version.
    August 2005
Posted by eizzle on Friday, December 16, 2005 10:07 PM
Ok, I get it now. The one I have isn't made to go inline, it is made to go on right at the tank, that is why I was thinking don't splice the hose, this is easier. It does make sense, to let the water condense, but I also think if the mostiure is there, its going to collect on the stone that is inside the trap, at least that is how mine is. Anyhoo, good luck Rob.
Colin
Posted by Anonymous on Tuesday, December 20, 2005 12:21 AM
Well, I got it on, its not pretty, the braiding started to fray o I teped around the ends and it looks like a hnk of garbage but it gets the job done.
