As mentioned in my other post I bought the Peak C-5 from BearAir.
tho9900,
I noticed that you mentioned you may get one of these.
I am just about
setup to try and airbrush tomorrow.
Is there something I can paint or
do basic strokes, lines, etc.. to show on the
board here that may help
you make a decision? Any color schemes? Put a scale against lines?
I know this will be my first try at airbrushing so you may not get a
lot out of it.
But perhaps with some practice I can show you something.
Just some info from holding the brush: It is similar to an Iwata eclipse size. The trigger does not
have a lot of downward movement. The movement seems smooth. When I pulled down on a
Pasche there was more downward movement. The BearAir rep said because they have more
air going through them. So may not have as much control of air? But the downward movement
was similar to the Iwata I had in my hand.
