1/72 German "squiggly" advice needed
    February 2005
Posted by Jabbe on Saturday, December 24, 2005 12:33 AM
Hi all,
I'm currently building a RM 1/72 Me 262 nightfighter. The instructions call for squigglie (lounge?) painting. I'm using a cheap single action airbrush that can't really make such small marks. I was hoping anyone might have some advice on a technique that might produce the desired effect. I was thinking a notecard, with "squigglies" cut out and held just off the surface would work, but it seems like an aweful lot of work. Any better ideas?
Joshua
    June 2005
Posted by MontanaCowboy on Saturday, December 24, 2005 2:34 AM
Hmmmm. I'm not sure, I would go notecard style, that's what I'm doing on a 1/35 Pz IV with spotted camo. I don't know how that would look with the squiggles, though. I have seen many good models with hand-brushed squiggle camo. I would definately go the soft mask way. Take a lot of time on it, and it will look great, I'm sure.
"You know, Life is like a Rollercoaster. Sometimes you just die unexpectedly." No wait, that's not it.
    April 2005
Posted by wing_nut on Saturday, December 24, 2005 6:06 AM
Joshua
I think in that scale you would do better with a brush application.  A nice continous hard edge pattern will look better than a soft one that is broken up.  The card idea may prove to be difficult for that kind of pattern, like if you tried to make a card for the letter "O".  How to you hold the center piece in tyhe card to make the circle?
If you use a brush used for pinstripping, long thin bristles so it holds a lot of panit to make long lines, I think would look fine.
Marc
    August 2004
Posted by Tankmaster7 on Saturday, December 24, 2005 12:34 PM
or paint the color of the squiggle first, make long thin rollds of blutack putty and then spray the other colors.
-Tanky Welcome to the United States of America, a subsidiary of Exxon Mobil Corporation, in partnership with Halliburton. Security for your constitutional rights provided by Blackwater International.
    April 2005
Posted by wing_nut on Saturday, December 24, 2005 10:34 PM
DOH!   Yup that should work  Big Smile [:D]
Marc
    August 2003
Posted by tweety1 on Monday, December 26, 2005 7:08 AM
Easiest way in 1/72 is to find a pencil the same or as close as possible to the colour you need and use that to draw your squiggle on.
It is best to apply a flat clear finish first, it gives something for the pencil to 'bite' onto.
With just the right amount of pressure, you'll get the appearance of a sprayed application unless you look REAL close.
I stumbled on this method when trying to do squiggle on my 1/48 Hs-129.
In 1/48 it looked drawn, but for 1/72 it would be perfect I think.
My 2 cents [2c]
--Sean-- If you are driving at the speed of light and you turn on the headlights, what happens???
    July 2004
Posted by tho9900 on Monday, December 26, 2005 4:45 PM
Wow... that's a really good idea Tweets! I have a couple of 1/72 German birds... I'll have to try that on one of them!
    August 2003
Posted by tweety1 on Tuesday, December 27, 2005 5:15 AM
Don't forget to post pics Tom
    July 2003
Posted by KJ200 on Tuesday, December 27, 2005 5:38 AM
Joshua,  I'd be inclined to go with the  Blu Tak method as I've had good  results with this in the past, but that pencil method sounds interesting.
Karl
    February 2005
Posted by Jabbe on Tuesday, December 27, 2005 10:21 PM
Thanks for the help guys.
I had thought about painting the brown, then grey on top, but I decided not to for some reason. Perhaps I thought it would turn out too dark. In retrospect, it sounds like that might have been the best idea. I think I'll try either the brush or pencil method.
Joshua
