Tamiya Acrylics
Tamiya Acrylics
Posted by rodc on Monday, January 9, 2006 8:43 PM
Hi,
I have been purchasing Tamiya acrylics as of late from my LHS since they are somewhat cheaper than the ModelMaster enamels I am accustomed to.
I usually do not use acrylics and was wondering if anyone had any wisdom to impart about their use....i.e. problems I may encounter using them in my airbrush, problems curing to primer base, etc.
In addition, I also purchased a couple of small bottles of Tamiya acrylic thinner but was wondering can these paints be thinned with something a little more economical.
Any advice would be appreciated. Thanks!
RODC
    February 2005
Posted by mamillar on Monday, January 9, 2006 9:26 PM
You can thin them with plain Isopropyl alcohol and it works great. If you smell the paint, you can smell the alcohol in them. The only real problems you may get are the fact that they dry real fast and can almost dry before hitting the model. I have heard others talk about using an "acrylic retarder" to slow down the drying process. I usually use the Tamiya paint to lay down a dead flat base color for spraying Lifecolor or Vallejo paint as well.
    February 2005
Posted by mamillar on Monday, January 9, 2006 9:45 PM
Forgot to mention. I use the Tamiya paint as a primer as well. This stuff sticks to the bare plastic better than any other acrylic I have seen. I never have to prime before using it. One thing to remember is that Tamiya is not to great for brush painting. You also should keep some alcohol and a cotton swab handy to clean the nozzle/needle tip of your airbrush while painting as the Tamiya can dry up and clog the tip pretty quick.
    May 2005
Posted by Bgrigg on Monday, January 9, 2006 10:20 PM
I use Tamiya Acrylics exclusively, and thin using their thinner (buy the 250ml bottles it's way cheaper! If your LHS doesn't stock it, have him order it: X-20A 250ml item#81040). Which is basically isopropyl alcohol with retarder. You can certainly use straight iso, but it may cause gloss paints to dry flat. I'm planning on trying out the iso and retarder combo, but I bought enough thinner to last me a couple of years.
I blow Windex through the A/B to clean followed by distilled water. I keep a small container of Windex handy and Qtips to swab out the tips as acrylics does dry up very quick.
Get some needle lube (Medea Super Lube or Badger Regdab) to put on the front 2/3rds of the needle. That also helps with the potential dry tip problem.
So long folks!
    January 2003
Posted by plasticmod992 on Wednesday, January 11, 2006 2:26 AM
Like Brigg, I use Tamiya as well.  However, I have gone the alternate thinner route, and have had excellent results with Denatured alcohol.  It's available at my local Menards for $3.00 (1) Quart.  The colors airbrush wonderfully for general spraying and great finelines as well with no tip-dry or clogs, and no retarder added.  I start with a thinning ratio of 1:1 and spray to my hearts content.  Another advantage of the Denatured alcohol that I've noticed is that, it cleans the styrene very well, facilitating maximum adheasion without a primer.  I also use it to clean the airbrush out after painting sessions.  Here's what I've been able to do with Tamiya acrylic for this recently completed 1/72nd scale F-111F.  Just FYI, my airbrush is a Iwata HP-CR.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
    September 2004
Posted by Borg R3-MC0 on Wednesday, January 11, 2006 6:11 AM
I use windscreen wiper fluid to thin Tamiya acrilics. Winter mix has a lot of alcohol in it, so it works just the same.
Posted by Anonymous on Wednesday, January 11, 2006 6:30 AM
Hello-
I have been using Tamiya acrylics for the last 3 years almost exclusively. I have been building armor kits. I've had no problems with Tamiya, very easy to use and clean up afterwards.
I do prime all my models using a automotive lacquer based primer out of a spray can. The Tamiya acrylics go over it without any problems. Haven't had to do any masking due to the fact that the tank kits I've been building lately haven't required it. Always use a low tack tape for masking anyway.
I thin the Tamiya acrylics with rubbing alcohol that I buy at my local drug/variety store. Works like a charm! I use the very same rubbing alcohol to clean my airbrush with after spraying the acrylics.
Glenn
