airbrush paint spray problems
Posted by Anonymous on Tuesday, January 17, 2006 12:31 PM
OK, I'm brand new to airbrushing.  Here's the problem -- my paint is coming out watery, runny...does the cold weather (North CA winter; cold not snow) affect the paint that way or am I diluting it too much?  What is the best consistency of paint for airbrushing acrylics?  Is it the same as for hand brushing?   Thanks.  Chicoman
    January 2003
Posted by Triarius on Tuesday, January 17, 2006 1:13 PM
The paint should be thinned to the consistancy of thin (2 percent) milk as a rule of thumb.
Polyscale acrylics, for example, require little thinning, whereast Tamiya requires substantial thinning.
Generally, it is best not to thin for hand brushing. Again using Tamiya as an example, in warm or dry weather, dipping  your brush in a drop of isopropyl (90%) occasionally will keep the paint fluid on your brush.
What pressure are you using? Sounds like you could be using too low a pressure or too high a paint volume.
There's an article available from a pinned thread, here, called "The ABCs of Airbrushing." Download, read, and save for reference—its a great resource!
Most of this is a matter of experimentationBanged Head [banghead]—find what works best for you—but don't hesitate to ask questions.Big Smile [:D]
