I use a "garage" style compressor, private labeled from Home Depot $119
CDN bundled with a 2" nailgun and 25' hose. 120psi max, 2 gallon
circular tank. Noisy doesn't even begin to cover it, but it's outside
in a box with a 50' hose running to the spray booth and I can barely
hear it when it's running. Once filled the tank holds enough air for
about 10 minutes steady spraying before the compressor kicks back on
again. It has a regulator at the tank, which I have set for 50psi, and
another regulator with moisture trap at the "business" end so I can
knock that down to the 10-15psi I normally spray at. I crank it up to
40-50psi for cleaning.
The compressor has a dual purpose as it not only feeds my Badger 150
airbrush, but gets used to power my pneumatic nailgun and keeps the
kid's tires inflated. I'm slowly refurbishing my house, which was the
justification to replace my ancient 25psi hobby compressor, which
worked just fine and remains in my possession as backup. It was also
noisy, but not as noisy as the new one. It was indoors, so I'm glad to
have upgraded.
My plan is to buy a Badger 100G for the rare bit of detail work the 150
can't handle. Which isn't much! The neat thing is that the head
assembly, valve and needles are interchangeable betweeen the two
airbrushes.
edit The crescendo isn't a bad airbrush at all, the fine and medium needles are good for modeling, but the heavy is just too darn big for any real use. I find the body on it a bit fat, so I went with the 150 which offers the same options for changing the needles and heads. Actually I have two 150s, an 20+ yr old one with a medium head/needle and a new one with the fine head/needle. /edit
