So Mad I can spit
    January 2006
So Mad I can spit
Posted by DiscoStu on Wednesday, February 1, 2006 3:09 PM
Hey all, I've got some serious air-brush issues that may have already cost me a kit that was going really well.  I recently dropped my Omni 4000 on the floor which bent the needle and the tip assembly.  I re-ordered replacements for all the parts and everything was going fine.  Today it just started spitting paint, no stream, just spit.  After some intense cleaning, the spitting stopped but then it shot paint out to the side at about a 45 degree angle.  I adjusted the depth of the needle and tried again, spraying both acrylics and metalizers I got terrible results.  I tried using harsh language and threats, but that didn't seem to work.  Any ideas from you airbrush experts?
"Ahh the Luftwaffe. The Washington Generals of the History Channel" -Homer Simpson
    December 2003
Posted by thevinman on Wednesday, February 1, 2006 3:26 PM
Sounds like you might have a serious clog somewhere. Is air coming out of the tip? You might have dislogged something in your attempt to replace the head/needle. Try to clean it up again. Airbrushes are relativley simple devices, you should be able to fix it.
    August 2005
Posted by eizzle on Wednesday, February 1, 2006 7:20 PM
Did you bend the piece that goes on around the needle as well? UM, sorry I can't think of a name for it, the last piece in the head assembly?
Colin
 Homer Simpson for president!!!
    May 2005
Posted by Bgrigg on Wednesday, February 1, 2006 11:07 PM
I'm surprised the harsh language and threats didn't work. They normally do. Shock [:O]
It does sound as if something is blocking the flow. Have you torn down the brush completely, removed the o-rings and given it a good soak in thinner? There are times when a good soak in the tub works wonders.
Failing that, I would return the AB to Badger, begging their forgiveness for being clumsy and see what the repair cost will be.
So long folks!
    January 2006
Posted by DiscoStu on Thursday, February 2, 2006 4:16 PM
I left all the bits in a jar filled with thinner and let them soak.  Being the impatient modler that I am, I'm about to reassemble it and try again.  Hopefully without the harsh language this time.
    January 2006
Posted by DiscoStu on Thursday, February 2, 2006 4:17 PM
Nope.  Replaced that too.
    May 2005
Posted by Balearic on Thursday, February 2, 2006 9:35 PM
I'm having a similar problem with a Badger 150.  Up until a few weeks ago, it usually worked beautifully.  But for some reason, lately it's done weird things like refusing to spray blue paint for more than two passes (up, down, no paint -- run the needle in and out --- up, down, no paint -- rinse and repeat), or working terribly with one color, working well with another, and then being somewhere in-between for a third -- and paint brands don't seem to matter (Tamiya, Polly-Scale, G-S, Accu/ModelFlex, etc.).  Because the paint sometimes splatters, I thought I might've split the tip/nozzle, but that seems okay.
Tonight I was able to successfully shoot a part with blue paint before it quit, so after a rest I tried to paint a caboose.  The paint tended to start out too wet, then quickly started drying on contact, before finally cutting out completely.  I clean the stupid thing religiously, but I've noticed some paint clogs in the nozzle lately.  So, will I have to just disassemble the poor thing and try to reassemble it, or is it time to bury it and start using a Paasche or Iwata?
    May 2005
Posted by Bgrigg on Thursday, February 2, 2006 9:47 PM
Nope! That Badger should work for decades, I have one that is well over 20 years old. You may have a split tip but just can't see it with the naked eye. But my recommendation is disassemble and clean it real good.
If that doesn't work, I suggest sending it to Badger for a tune up.
So long folks!
    May 2005
Posted by Balearic on Friday, February 3, 2006 11:57 AM
I've been removing the entire tip assembly and cleaning that, and running pipe cleaners into various passages.  I'd rather not pull it all apart for fear of destroying something.  I've examined the tip by sight as well as by running my finger and a piece of paper over it, and there's no evidence of a crack or split.  This is driving me nuts.
Thanks for your help.
