this will be the 1st time i paint a scale model, so i'm starting off with an efini rx-7 from tamiya.
i have paint including the rattle cans for the body of the car, since i don't have an airbrush.
3 different sized brushes, 2 round ones, 1 flat one
clippers
tamiya cement.
i'm considering getting alcohol to thin the tamiya acrlyic paint, but i
looked inside the bottle and it looks pretty thin, if not should i use
water?
now b4 i start, how should u paint and construct? like wat do u do
first? do u build a small part, then paint or do u paint the parts
separately, let them cure, then assemble? also when is the right time
to use the tamiya cement?
thanks
