Wash on Acrylics?
Wash on Acrylics?
Posted by Anonymous on Friday, August 1, 2003 8:28 PM
The group has already been asked this question a million times so I apologize in advance.
I am back into modelling after 20 years and loving it. I am presently building 1/48 Revell B-1B using Testors acrylic paints.
I would like to do a wash on the landing gear to show detail. Do I use oil? Can I use acrylic paint. (that is what I have).
What are the steps to doing a wash, everyone talks about it but I have not been able to put it in steps.
Even if there is an article that I should be reading if someone could direct me to it.
Thank you again!
Tongue [:P]
    June 2003
Posted by allan on Friday, August 1, 2003 9:45 PM
Hey there Darren.
I use oils myself. Its usually a mixture of burnt umber and prussian blue, but may vary depending upon the effects I want to achieve. I mix about 20% oils and 80% thinner (ratios may vary) and dip a pointed brush into the mix. Using the brush I then allow the oil wash to creep along the creases, panel lines and corners.
If your asking if you can use acrylics for wash, I dont suppose you can do that. Acrylics do not have the same consistency as oils, and will probably be just too thin to use as wash. Oil washes are best applied over acrylic and lacquer finishes, as the thinner in the wash may affect enamel finishes unless protected by a sealer coat.
Hope this helps.
No bucks, no Buck Rogers
Posted by Anonymous on Saturday, August 2, 2003 9:34 AM
Thank you. So I can use oil washes on acrylic paints!
Posted by Anonymous on Tuesday, August 5, 2003 2:58 AM
what do you use to thin the oils? Are you speaking of actual oil paint like for canvas art or is there an acutal "oil base" modelling paint?
Posted by djmodels1999 on Tuesday, August 5, 2003 3:34 AM
Yes, the paints we are talking about here are those that come in tubes, marketed for 'artists' and canvas art.
And yes, oils will work just fine over acrylics.
Posted by Anonymous on Tuesday, August 5, 2003 3:28 PM
Thank you. I wish there was some sort of video that was a sort of tutorial for this sort of thing. Big Smile [:D]
Posted by Anonymous on Tuesday, August 5, 2003 3:30 PM
oh one more thing. What do you use to thin the oils that will not hurt the acryl paint? Question [?] Thanks for the time.
    June 2003
Posted by allan on Wednesday, August 6, 2003 9:05 AM
Unknownpharoah, paint thinner (for enamels) will work just fine.
