- Member since
Posted by jhande
on Thursday, February 16, 2006 12:10 AM
I've tried a few techniques, all seem better for how accessible the emblem is.
- Dry brush, slide the bristles sideways over the emblem.
- Flat toothpicks (or cut craft sticks, tongue depressors), dab a thin layer of paint and gently lay it down on the emblem.
- Use a 30/0 brush.
- Paint the emblem first, then paint the surrounding area. If
spraying the surrounding area, you can dab a small amount of vaseline
to cover the emblem. When the paint dries you can wash it off.
- Use an old dried out fine-tip marker, dip the tip into the paint and tap it on the emblem. Repeat until emblem is covered.
That's a few I can think of right now.
-- Jim -- "Put the pedal down & shake the ground!"
