Alclad gloss black base coat question
    June 2005
Posted by tedhealy on Thursday, February 16, 2006 3:20 PM
I'm making my first alclad2 attempt and I have a question.
I airbrushed alclad gloss black lacquer as my base coat on a p-47 with the intention of using alclad2 aluminum.  I initially started with something closer to 20psi rather than 10.  In the area on the wing where I started with that pressure, the paint is somewhat bubbling.  It looks like many tiny little bubbles.
After turning the pressure down, this did not happen again.  Will these bubbles go away as the coat dries?  If not, can these bubbles be sanded and/or polished down or off after the paint dries?  I assume a 2nd coat wouldn't help and would just make the bubbles bigger.
Thanks for any help.
    July 2004
Posted by tho9900 on Thursday, February 16, 2006 8:56 PM
Ted - I use Future as my primer, I've had bad experiences with the Alclad black primer myself.. 2 months after putting it on it was still sticky!!!
Alclad's site listed Future or enamel primer sanded with 1200 grit as primer for non-shiny metallizers... I found future to be a dream!!  if ya want spray some acrylic or enamel black first.. I didnt and it worked fine but I am going to try it with the black on my current build.  I would lightly sand the primer with a fine grit to get rid of any bubbles...  then maybe future would be your best bet!
(Let it cure for at least 24 hrs first!!)
    June 2005
Posted by tedhealy on Thursday, February 16, 2006 10:16 PM
In taking a closer look at the finish as it has dried, it isn't so much bubbles as it is sort of a mottled appearance.  The surface definitely is not as glossy as the rest of the plane, but it is not really rough or uneven.  Maybe the surface wasn't as clean as it should have been, I don't know what went wrong.
So I could sand the offending area and then go straight to the future?  Or should I shoot a 2nd coat of the alclad black and then the future (after waiting for cure time)?  I definitely won't be using the alclad black next time.
    February 2006
Posted by Neptune48 on Friday, February 17, 2006 5:13 PM
tho9900,
By any chance did you use lacquer thinner with your black undercoat?  If so, it's time to strip it and start over.  In the fine print on the bottle is says the Alclad black contains MEK.  If you mix MEK and lacquer thinner you get a clear sludge, and the paint won't dry.  Thin the undercoat with MEK (using the proper precautions while handling) and I think you'll like the results a lot better.
Regards...
"You can't have everything--where would you put it?"
    July 2004
Posted by tho9900 on Friday, February 17, 2006 6:16 PM
 Neptune48 wrote:
tho9900,
Regards...
No I shot straight from the bottle... it was wierd, I played it off the the humidity down here but I've heard the same story from a few other people, it went on smooth with no problems it just never dried might less cured...
Ted - If you plan on shooting more of the black primer on don't worry about Future, I probably would lightly sand that spot with a high grit paper until smooth then reshoot black primer over it... I use future from the start as the primer itself.. good luck to ya!
    December 2005
Posted by jamalone on Friday, February 17, 2006 6:52 PM
Really weird.  I shot alclad black base first coat straight from bottle.  That sucked, same bubbly almost fisheyed appearance.  So I stripped with denatured alcohol (didnt bother plastic which was nice).  Second coat I actually thinned with laquer thinner about 50/50.  Went on really nice, however it took 4 days to dry.  Still have to do top half of model I think Im going to strip it again and use tamiya gloss black but need to be sure that is works with polished aluminum as it is shinier finish.  Definately wont be using the alclad primer again, Ive heard nothing but bad about it.  Just my two cents worth.
    January 2003
Posted by Triarius on Friday, February 17, 2006 7:40 PM
What your photographs show appears to be "crawling," as the paint industry calls it. This can have a number of root causes, but it results from either poor bond to the substrate, excessive coating shrinkage, or both.
From your description, the primer appears to be a water-solvent or similar system, as an organic solvent material would probably not be affected by alcohol (although there are some really strange formulations out there.) Lacquer thinner will patially dissolve the styrene—you get great bond, but all the solvent that migrated into the styrene will take days, if not weeks, to migrate out past the coating. That's why it's taking so long to dry.
The "fish-eye" problem you report is caused by localized contaminations—usually oil, but potentially anything—that repel the resin or solvent in the paint. What the contaminant is, in your case, I have no way of telling. It could even be something in the primer, itself. Figuring out what would take a paint lab.
Hope this clears up a little puzzlement.
    December 2005
Posted by jamalone on Friday, February 17, 2006 9:19 PM
Thanks for the reply, Triarius..  So do you think its an acrylic based primer or laquer? Some say one, some the other, I dont know which.  Sounds like acrylic.  I went ahead and sprayed the top of my b25 tonite with the same 50/50 mix of laquer thinner/primer and it went on great.  The  thinnner doesnt seem to mind mixing with the primer.  I know my first coat sucked because apparently I didnt clean with soap and water after using a plastic polish to get a better surface.  I think I got it too slick.  I did use rubbing alcohol to clean model before spraying but maybe it didnt get all the polish/wax?  Next time, no polish.  Let me know what you think.
Aaron
My new spray booth:
    January 2003
Posted by Triarius on Friday, February 17, 2006 11:19 PM
AHA! Some plastic polishes have materials in the carrier that will interfere with some paint systems. Not cleaning thoroughly after using them may well have caused the crawling and fisheye problems. The actual smoothness of the surface should not be a factor.
I don't know what the formulation of the primer is. A true "lacquer" cannot be an acrylic. A lacquer forms a film through evaporation of the carrying solvent, not through true polymer formation. Basically, they are a resin dissolved in a compatible solvent. Lacquers form a continuous film that can be dissolved by reapplication of the original solvent. Some lacquers use alcohols as solvents, some more modern formulations use other organic solvents. None of this precludes the primer being some odd polymer forming coating that behaves in some ways as a lacquer. When you took it off with alcohol, did it dissolve, or did it come off in sheets and clumps? If it dissolved, it's an alcohol lacquer. I suspect this is the case, because a lacquer-like paint using water as a co-solvent would not tolerate lacquer thinner.
That's a nice looking spray booth!
    April 2004
Posted by crockett on Saturday, February 18, 2006 8:08 AM
Well, there certainly is a lot of scientific "speak" in this thread. I would just boil it down to simplicity. Use Future as a primer for Alclad II and you can't go wrong. Allow it to cure for at least 24 hrs. The results are great:
I use Tamiya polishing compound on the bare plastic, washing it off with isopropyl alchohol, then apply Future to the bare plastic......then shoot the Alclad II .....? works for me.
Steve
    July 2004
Posted by tho9900 on Saturday, February 18, 2006 10:40 AM
Steve - that's what I've settled on as the best finish for shooting Alclad onto.  Did you use a black base coat before shooting the future on with either one of the pictures you posted?  I've pondered trying it to see if it brings out a little more brilliancy on the metal sheen...
    January 2003
Posted by Triarius on Saturday, February 18, 2006 10:41 AM
Paints are technical, and astonishingly complex—and what I posted was significantly "detechnified," if I may coin a phrase. I once worked with a paint chemist who had great trouble doing that. I barely understood him sometimes, and I had to translate for him! Confused [%-)]
I have a strong tendency to answer the question asked, which in this case was, "What went wrong?"
Your answer was to the question, "How do I avoid this mess entirely and save a few bucks in the process?" This is a good cap for the discussion! Thumbs Up [tup]
Nice paint jobs, by the way. I just bought some Alclad II at my "local" hobby shop. Thanks to everything I've read at these forums, I did not buy the Alclad primer, and I will be using essentially your method.
    January 2003
Posted by Triarius on Saturday, February 18, 2006 10:44 AM
He said he used Future on bare plastic, Tom.
If you try using a base color under the Future, I'd be interested in the results!
    December 2005
Posted by jamalone on Saturday, February 18, 2006 10:54 AM
It seemed to come off in little specks no bigger than say /16th of an inch.  I use cotton swabs soaked in the denatured alcohol.  It seems to dissolve it as I was going along.  So I agree with you on that one.
Glad you like the booth.  It worked awesome last night.
    December 2005
Posted by jamalone on Saturday, February 18, 2006 10:55 AM
Crockett, does this work using the polished aluminum as well?  I know they want some sort of black base on this and the chrome.
    June 2005
Posted by tedhealy on Saturday, February 18, 2006 2:10 PM
Thanks for the help everyone.  I just sprayed my first coat of alclad2 aluminum and it looks great.  It went on a lot easier than I thought it would after struggling with the black primer.  Very easy and no more fear of doing a bare metal finish.
I ended up sanding down the trouble spot and then spraying future over the entire model.  That produced a nice glossy black base coat.  I'll probably spray a 2nd or 3rd coat of the aluminum later today, let it dry, and maybe take a shot at masking off some panels for duraluminum.  I'll post pics of it later.
    April 2004
Posted by crockett on Saturday, February 18, 2006 7:34 PM
No black primer, or primer of any kind. The brilliance satisfies me. The key is to polish the finish of the bare plastic so as not a speck of anything is on the surface. Alclad will make a microscopic piece of lint look like a banana peel on the finished surface!
I know Matt Swan advocates decanting Krylon gloss black, and I certainly can't argue with the Swanny! but for me, a coat of good solidly cured Future does the trick.
Steve
    April 2004
Posted by crockett on Saturday, February 18, 2006 7:37 PM
I just used polished aluminum and chrome on my P47N, just plain old Future on bare plastic. Keep an eye on the aircraft forum in the next couple of days for finished pycs...
SteveWink [;)]
    December 2005
Posted by jamalone on Saturday, February 18, 2006 10:24 PM
Cool, cant wait.  I wonder could a person spray flat black and then future.  I guess it depends of how much work one wants to put in.  Do you thin the future with anything to airbrush?
Thanks
    April 2004
Posted by crockett on Saturday, February 18, 2006 10:39 PM
Thanks
Nope, straight from the bottle.......
    July 2004
Posted by tho9900 on Sunday, February 19, 2006 8:24 AM
I thin mine but that's just personal preference, I use Tamiya Acrylic thinner... it gives it a speck more drying time and to me allows for a smoother finish.. like a mirror glaze.
Well I took the jump and since we were talking about it in this discussion, I first painted black acrylic on the nose of my Do335, this morning I am going to put the Future down and tomorrow the aluminum, I'll post pics here when I am done.. I am just curious how it is going to work out...  I did use polishing sticks, then micromesh to get the nose as smooth and shiny as possible.. and that, with the future should provide a good finish...
Usually I have used just future but I just thought this a good experiment...
I tried the Krylon thing, didn't get great results with it.  I know there are those that do, but I'm sticking to future...
    December 2005
Posted by jamalone on Monday, February 20, 2006 10:05 PM
Well, here is the first half of my B25 with polished aluminum.  I love the sheen, but man you HAVE to have a perfect surface.  Will see how the rest goes tomorrow.
    June 2005
Posted by tedhealy on Monday, February 20, 2006 10:29 PM
Here's my alclad effort, thanks again for the help.
It is aluminum over alclad gloss black primer and then future.  There are a few more pics in the aircraft forum.
    April 2004
Posted by crockett on Tuesday, February 21, 2006 12:12 AM
Jamalone,
You're going wheels up? It looks like you've lost a lot of panel line detail on that belly, shouldn't you have rescribed before paint? The bombay doors appear non-existant....????
Steve
    December 2005
Posted by jamalone on Tuesday, February 21, 2006 6:01 AM
Crockett, because of the way this is going to be mounted (on a rod about 8 inches high on a wood base) one isnt going to be able to see the bottom.  I did lose a little detail but only the seam where the two bomb bay doors meet in the middle.  You can still see some from the side although not visible from the pic.  I had to do some major mods to get the bomb bay doors to meet around the piece of square stock inside the plane.  Its the monogram B25J, not a lot of detail down there anyway. :)
    April 2004
Posted by crockett on Tuesday, February 21, 2006 5:00 PM
Cool, The old monogram still looks like it builds into a decent B-25. The finish is striking. Not to many modelers on this site do "in flight" presentations, so I'll be looking forward to seeing yours finished.
Steve
    December 2005
Posted by jamalone on Tuesday, February 21, 2006 5:39 PM
Im at the stage now after spraying that all these imperfections like dust spots etc, are really starting to annoy me. Im seriously thinking about stripping all down and starting from scratch with the paint again.  This paint job just doesnt do it justice.What a learning curve.  Of course this means new canopy, rescribing some lines around the bomb bay (smile) and the like.  Any body know of anything that would strip this?  Would oven cleaner? This project has taken me since November 1st of last year.  I really like the lines of the monogram kit though.
Crockett,  they say only pilots build with gear up!! :)
    July 2004
Posted by tho9900 on Tuesday, February 21, 2006 8:28 PM
Well just for curiousities sake I am trying that right now on a Do335 Pfiel trainer, when captured this aircraft had a NMF nose to it so I sanded to 2000 grit with sandpaper, used polishing sticks till glossy, then put Vallejo black down on it (it goes down smoother than other acrylics so don't know how it works with the others) and have 3 coats of future on it now, going for maybe one more, then the Alclad... I've used the Alclad over plain future, I just want to see for myself about the black and if it indeed increases the brilliance of the alclad..
I've sprayed other models with nothing but future and been extremely happy with it, but curiousity killed the cat, so I am trying it with a black base on this one.  I should have pics by the weekend so I will know by then, and can give an opinion....
    July 2004
Posted by tho9900 on Tuesday, February 21, 2006 8:33 PM
Ted - looks like all's well that ends well... really nice job!!!!
Jamalone... nice looking finish!!!  I too would like to see the finished product on the stand and all...  As far as stripping, I know Castrol Super Clean will get off poorly adhered Alclad but not sure about cured and well glued down to the body Alclad...
    February 2006
Posted by Neptune48 on Wednesday, February 22, 2006 8:33 PM
There's no comparison when using Polished Aluminum or Chrome.  Without the black base, they're just semi-shiny silver.  With the black base you get a deep polished appearance.  The picture attempts to show the results of an experiment I tried a couple of years ago, though my lighting isn't very good.
