- Member since
Posted by Anonymous
on Wednesday, February 22, 2006 6:28 AM
Bgrigg wrote: | qmiester wrote: |
Testors and Humbrol both produce charts of their products and usually can be found in the LHS that sell them. One thing you need to remember that they may not be too accurate. When printing the charts, inks are used which usually lead to a caveat being printed somewhere on the chart - "Due to the limitations of printing inks, some colors on this chart may not be an accurate representation of the actual color of the paint" or words to that effect. |
Quoted for truth! The only 100% accurate way to represent paint is to use paint, which is a very expensive process. Only four colors are used in color printing: cyan, magenta, process yellow and process black. A slight deviation in color, pressure, registration, inking, fountain solution and blanket packing can throw off the color.
Dragon USA imports Gunze to the US http://www.dragonmodelsusa.com. As they are a wholesale distributor, they may refer you to a dealer.
Some other factors would include poor color seperation, dot gain, worn/bad set rollers, linting, fluctuations in ph and conductivity of water all would affect the color. 4 color printing = 3 process colors: cyan magenta yellow + Black
