Bgrigg wrote: |
I've had this issue when I've overthinned the paints. If you're using alcohol to thin with (Tamiya Thinner is alcohol with retarder), the paint is actually drying before it hits the model. Try using less thinner and more pressure.
I use a fluourescent bulb in my spray booth, but the 2 75 watts aren't helping any! Consider switching the bulbs for those (expensive) twisty fluourescent types, they burn much cooler. And last much longer, and save on electricity so the expense is made up in the long run.
The other thing that may be causing this is the venting. While it may seem that the faster the air is evacuated the better, there is a point where it works against you as it causes what little paint does get to the model to dry out too fast.
I very well may be overthinning. I know the 2% milk rule and that's what I try to achieve but lately I've been trying to thin to something that resembles Alcad. I'll change my ratio and see if it helps. Also, I use both MM Acryl thinner and alcohol and they both give me the same results.
I have a couple of the fluoursecent type laying around. I'll try those also. The thing I've found about these is that even though they may be rated the same in wattage as an incandescent they're not as bright. Could be my imagination.
My venting system is actually an old fan ass'y used in a kitchen above the stove/oven for exhaust. It has two fans in the housing, one on each end, and draws VERY well, maybe too much? I'll save this idea for last since it'll be the most difficult to alter.
On a side note and FWIW, I'm not a big fan of Tamiya paints, not out of an a/b anyway. It's never been an issue with color or selection but of how fast it dries. There's a red flag here with my paint issue and I'm beginning to lean toward the "too much heat/air" theory. I'd really like to use some of my Tamiya paints. Maybe if I get this thing under control I'll be able to do that.
Once again, thanks for your comments and ideas. As always, you're a kind help.
Hud
