I'm currently conducting an informal experiment, spraying 24 different metallics (15 Alclad II, 9 ModelMasters and Testors enamels) over 9 various colors of undercoat. i', 2/3 finished, and so far I've found that some Alclads are more transparent than others, and the base color shows through. This is particularly so with Titanium Gold.
Alclad high-finish colors (chrome, polished aluminum) must have a high-gloss black undercoat to get the depth of reflection. For most of the other colors, the critical factor seems to be the surface of the undercoat: the glossier the surface, the shinier the finish metallic coats. The Aluminum variants cover well, but the surface will be affected by what's underneath.
An "primer" coat of Mr. Surfacer 1000 or 1200 provides two big advantages: 1) it provides an even surface color over any material, which should help with the more transparent metallics,, and 2) it shows up any flaws in filling and sanding so you can rework them before applying the metallic. It can be polished with toothpaste or automotive rubbing compound. Be sure to clean the surface thoroughly before shooting the Alclad. Mr. Surfacer isn't called a primer but rather a filler. However, it has served me well in both applications.
For Chrome and Polished Aluminum I shoot Alclad II Glossy Black Base Coat or Scalecoat Locomotive Black (with Scalecoat's dryer added) over Mr. Surfacer. I haven't used Future as an undercoat, though I noticed some Alclad labels recommend it. It would certainly provide an ultra-smooth surface for the metallics.
Alclad contains MEK, and will craze enamel (and perhaps some acrylic) undercoats. Future could provide a good barrier to protect them. Always wear a respirator, especially when working with such nasty solvents as MEK.
Hope this helps.
"You can't have everything--where would you put it?"
