Dumb Question maybe about finishes
Posted by Anonymous on Wednesday, February 22, 2006 6:06 PM
I'm new really when it comes to acrylics seeing as  I've  come back to modeling now with the Future thing happenning (awesome stuff)  I got some  Tamiya  flat base . my question is it seems  aweful thick  kinda  like  a  semi gel...does  that mean its  bad?
    January 2003
Posted by Triarius on Wednesday, February 22, 2006 6:20 PM
No, it's not bad—it's supposed to look like that. The flat base is meant to be mixed either with Tamiya Clear Gloss (or a Tamiya gloss paint) to produce different levels of sheen. You can also mix it with Future rather than the Tamiya gloss.
The flat base is slightly thixotropic—a fancy word that means it will become slightly more liquid when  you stir it, which you should before mixing with Future or Tamiya.
I have found I get better results thinning the Tamiya Flat Base + Future mixture with about 10 percent isopropyl (80 to 90 percent) by volume. I use a ratio of flat base to Future of about 1 to 4 for very flat. Play with it. One large bottle of flat base will last a long time.
    August 2005
Posted by Phil_H on Wednesday, February 22, 2006 6:25 PM
No not at all.
Tamiya X-21 Flat Base is not intended as a clear coat in its own right. It's sole purpose is as an additive, to be mixed with gloss finishes (both clears and colours) to make them "flat".
Once again,  DO NOT attempt to use the flat base on its own as a clear flat coat. If you do this, you will get a sometimes sticky, chalky white goo all over your model. However, mix it with X-22 Clear Gloss, (approx 4 parts clear, 1 part flat base) and this should give you the desired result. (as always, experiment a bit with the mix ratios to get the desired level of "flat")
    May 2005
Posted by Bgrigg on Wednesday, February 22, 2006 6:29 PM
This is SO true! Been there, done that, have the sticky, chalky white gooey tshirt! Sign - With Stupid [#wstupid]
Properly mixed with Tamiya Clear or Future and you get a lovely satiny to matte finish.
There are no dumb questions, only dumb answers. My wife tells me I have plenty of those! Clown [:o)]
So long folks!
    January 2003
Posted by Triarius on Wednesday, February 22, 2006 6:46 PM
Frosty, the Corsair, didn't have a shiny nose!
(or anything else, for that matter.)
Mine actually dried to a frosted glaze—severe icing conditions, that's it! Really, that's what I was trying to model…
Clown [:o)]
I wonder how many have made this mistake?
Posted by Anonymous on Wednesday, February 22, 2006 7:22 PM
Thanks folks for the replies I was wondering, so gonna spearament with some future/flat base thanks again
