Painting Spinner Stripes
Posted by Anonymous on Sunday, February 26, 2006 7:45 PM
I am have used decals for spinner stripes (for example...the yellow stripe on the nose of the 357th FG)...but now i want to paint them on instead....but....i have no idea....tried tape...ugh...tried parafilm...crappy lines were the result....HELP!!
btw...i am a reader for many years...great tips guys!
    February 2006
Posted by Wulf on Wednesday, March 1, 2006 1:25 PM
Try this....
Let say if the spinner is black and the stripe is white...
Paint the spinner white first. Then place the decal as you would normally. Don't place it for the duration, you'll want to remove it later. Then paint the spinner black(over the decal) and let dry. Then, remove the decal. Lift it with some mask tape. It should come right off. You should then have your white stripe where the decal was. Good luck
    December 2003
Posted by hkshooter on Wednesday, March 1, 2006 3:26 PM
I used Microscale liquid mask for this just lastnight. Sprayed the spinner yellow over all. When dry coated with liquid mask. When dry used a new blade and scored the inner band. Used masking tape to remove portions of  mask I didn't need. Sprayed the red. When dry used the tape again to remove the the remaining mask. Worked like a charm.
    January 2003
Posted by Jeff Herne on Wednesday, March 1, 2006 3:46 PM
Confession time – I've been absolutely terrible at this since I started modeling 30+ years ago. I recently finished the new Hasegawa Stuka and lo and behold, a spinner decal.
I fought with it for nearly two hours with no luck, I couldn't get it to settle down and line up, much less conform to the curves of the spinner.
I tried parafilm, not much better. I finally decided to try my hand at hand painting, which is relatively easy on smaller scales but pretty noticable on 1/32 scale.
I found a piece of brass rod that fit the spinner, chucked it in my lathe and adjusted the speed of the lathe as low as it could go. Then, with a liner brush and a steady hand, painted a line from the tip of the cone to the base. It was perfect, only had a couple of small touch-ups to make.
If you don't have a lathe, try a variable speed drill with a lock setting. The lower you can adjust the speed, the easier it is to paint the stripe.
Jeff
