RotorRob60 wrote: |
Is it possible to mix gloss enamel paint with something to make it a flat enamel?
There are various forms of microsilica that can be used to do this. Cab-o-sil is one brand I recall. Don't know where you would find it in small quantities, but it's probably available. (40 pound bags, I believe.)
Be aware that this is respirable silica, and therefore dangerous.
Mixing a dry flatting agent into your paint will also change the pigment load, and may affect performance of the binder. It will also reduce the viscosity.
As other have suggested, a coat of clear flat is more efficient, and probably more economical.
