A somewhat embarrassing question....
Posted by Anonymous on Sunday, March 5, 2006 10:23 AM
I'm very new to airbrushing, and am still experimenting with my first few practice sessions. I've hit a small snag, but I'm sure there's an obvious answer. I'm using the Badger 155. Yesterday when I depressed the trigger for air flow I got a consistent flow of paint. The brush had been cleaned since it's last use, and the paint I was getting was more than just a bit of excess buildup; it was being drawn directly from the cup. Correct me if I'm wrong, but shouldn't I be receiving only air when I depress (not pull back) the trigger?
    January 2004
Posted by MusicCity on Sunday, March 5, 2006 10:37 AM
The needle isn't seated all the way.  Loosen the needle chuck, push the needle lightly into the nozzle, and retighten the chuck.  It's a common problem with a simple solution.
    May 2005
Posted by Bgrigg on Sunday, March 5, 2006 10:40 AM
Yes, you should only get air. Check to make sure that the trigger is all the way forward and that something is not blocking it. I'm not familiar with the 155, I have the 150, does it have a set screw on the trigger to help keep a consistant flow rate? It will be a tiny little screw at the front of the trigger.
Or what Scott said! He's probably forgotten more about airbrushes than I will ever know! Wink [;)]
So long folks!
Posted by MikeV on Sunday, March 5, 2006 1:35 PM
Scott is the man! Wink [;)]
