Model Master Question.
    February 2006
Posted by Shirako on Tuesday, March 7, 2006 6:51 PM
Are MM enamels supposed to be so thin? I just bought some  FS 33531 Sand to thin down to airbrush on my Abrams and and already seems thin enough to spray with no thinning, I have several MM paints but maybe I just never noticed how thin they are?
    July 2004
Posted by tho9900 on Tuesday, March 7, 2006 9:08 PM
Some of the MM colors are thinner than others, I have noticed some are thin enough to spray on their own and others not... I think with the yellows and whites especially they are thin by nature.. (sand being in the realm of those somewhere) ... when I used them I could spray some straight from the bottle, others needed various amounts of thinning... it was pretty much trial and error for which needed what...
Posted by MikeV on Wednesday, March 8, 2006 12:37 AM
I have noticed that with the Acryl line but not the enamel ones.
Is it that thin even after thorough mixing?
I was thinking maybe the pigments had settled to the bottom when you mentioned it being thin.
Posted by jhande on Wednesday, March 8, 2006 4:23 AM
I have noticed that with Testors enamels also. Some are so thin I need to brush a second coat, while others are so thick I almost lose the detail in the plastic.
I haven't gotten around to airbrushing yet. But when I painted cars, we wouldn't count on just a standard mix ratio, even within the same paint line. We would always do a drip test with the paint stirring stick, cheaper than a viscosity gauge.   Wink [;)]
-- Jim --
"Put the pedal down & shake the ground!"
Posted by ABARNE on Wednesday, March 8, 2006 1:47 PM
They usually are not that thin, typically being pretty decent from the bottle for brush painting, but there will be sample to sample varaiation.  Ironically, I too had a bottle of sand that airbrushed perfectly straight from the bottle, but I also another that was normal and needed thinning before airbrushing.  I've had other paints that were so thick, I needed to thin prior to brush painting.  It's because of this variation that I consider the concept of an airbrush thinning ratio to be worthless.
    February 2006
Posted by Shirako on Wednesday, March 22, 2006 10:56 AM
Well I bought some forest green to spray on the Abrams instead, and it sprayed perfectly from the bottle with no thinning at all, just some warming up with hot water and stirring, I bought another bottle and the exact same consistency as the Sand and previous bottle of forest green, made things alot easier for me lol
    June 2005
Posted by archangel571 on Wednesday, March 22, 2006 5:32 PM
I thought their Enamel II line (all numbered 2000+) come pre-thinned and ready for airbrush.  Shouldn't happen to Sand though.  I just sprayed their Zinc Green Chromate two days ago and it needed 3:2 paint to thinner for it to be laid down right.  It was giving me spiders when I did it 1:1 in ratio.
-=Ryan=- Too many kits... so little free time. MadDocWorks
    February 2006
Posted by Shirako on Wednesday, March 22, 2006 5:50 PM
I havent sprayed the Sand, but its consistency is very thin already, and the forest green layed on absolutely perfect, no thinning at all. maybe I just got lucky? lol
    January 2003
Posted by plasticmod992 on Tuesday, March 28, 2006 4:28 AM
This is true with the Model Master II colors.  These colors are or (were)  mixed in batches outside of the US, and when Testors discovered that a higher solvent content was added, they liked it, thus MM II colors are thinner in viscosity and most of the new FS colors are airbrush ready.  The MM II figure colors were manufacured a bit thicker for superior brush painting characteristics.  *Source: Testors Technical Manual.
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
