Yep, soaked the body minus the air valve. I agree with Mike, the needle bearing is not affected by lacquer thinner. Hooked the Anthem and 150 up to a can of propellent - Anthem smooth, 150 stuttered. I believe it is the head assembly seal.
The Createx cleaner worked on the 175, but it does not dissolve the paint the way thinner does. It "debonds" it from the surface, so you have to scrub most the paint particles loose. More labor, but less mess and fumes. Plus you have to soak overnite, unlike an hour or so for thinner.
Now how did this all happen? Had an all out acrylic sprayfest, Polly Scale, Tamiya, and MM Acryl. Two hours worth. That was during the holidays and I was too lazy to clean them at the time. Next thing I knew it was March. All that I still "hate" acrylics. I just don't have the patience to be easy with paint, although I may try Polly Scale again. MM enamels are very forgiving with little prep other than thinning. Thanks for all the help!
E
