Wilbur Wright wrote: |
Try a wash of very dilluted bleach maybe 10:1................apply with a q-tip to one small area, and let dry.
do not apply too wet.................this will not only kill it....it
will prevent it from re-occuring. just test the color fastness on a
small area like I said. AND make some provision for getting moisture
out of that case.
Yes, the bleach will kill it, but will also have a long term effect on the paint—chlorine is a very potent element. It will also not be as effective, long term. We tried* bleach solutions on such growths, and while effective, well established colonies in a good environment eventually come back.
That is why I recommended the Lysol. It contains a chemical that remains resident for a long time. Treating the interior of the cabinet alone may be enough to prevent recurrance.
A dual treatment is also worth considering: dilute bleach, rinse, Lysol. If it comes back after that, I recommend thermonuclear weapons…
Getting the moisture out of the cabinet is a good plan, but may not be practical. However, there is something else that can be done to improve the environment: add one ore more bright light sources to the cabinet. Fluorescent light (cool white) will increase the temperature slightly, reducing relative humidity. Mold and fungus also generally do not prefer strong light, and that may help, too.
Good luck.
*This is based on extensive research for architectural restoration done by my former employer and others.
