Aztek A470 Help please
    March 2006
Posted by thetecman on Tuesday, March 14, 2006 4:23 PM
My wife has bought me the afore mentioned brush and as I am compressor-less at the moment I got myself a can of air to practise with, when I depress the trigger of the airbrush however all I get is air coming out of the nozzle and bubbles in the pot. What, if anything, am I doing wrong and does anyone have any tips on getting the best from this product.
I have read elsewhere some good and bad reports of the Aztek products but cant really get rid of it as I want the missus to support my hobby(for once) and dont want to hurt her feelings.
I am using enamel paint at the moment but have been considering a move to acrylic.
    July 2004
Posted by tho9900 on Tuesday, March 14, 2006 7:00 PM
I used to own an Aztek and 9 times out of 10 when it did that, the nozzle was not on tight enough.  Take the little wrench for the head and turn it a bit more tight and try to spray, don't force it TOO hard as it might not want to come off, but enough to know it is tight.  Hopefully that will fix you up.
My Aztek did ok for me but there came a point when I felt like it was too much maintenance and that one of the brushes you see talked about a lot on here would do me fine.  If you ever come to that point, figure out which airbrush you want, talk about it and tell some of the high points to that brush and how you could use the Aztek for overall painting and the other brush for the detail etc...
If she pays attention to how much you like what you do and sees the results she'll be like my wife and buy that brush for ya as a present sometime.  Feelings are spared and you still get the brush you want.  But use the Aztek and see how it can do for ya.  I know many people here who do awesome work with it.  Also if something isn't working right with it there are a lot of current and former owners here to help ya figure it out.
Good luck!!
Posted by Kumy on Tuesday, March 14, 2006 7:26 PM
Yep the nozzle needs tightened a bit more.  I usually just finger tighten til its snugged up.  I never use the provided wrench but thats just me.  Canned air is an ok way to start out.  It helps to sit the can of air in a bowl of room temperature water.  I started out shooting enamels thru my A470 at first but have switched over to acrylics.  Have fun with your new airbrush!
    March 2006
Posted by thetecman on Wednesday, March 15, 2006 2:20 AM
Thanks guys I screwed the nozzle on better and have had good results thanks for the help.
    July 2003
Posted by zokissima on Thursday, March 16, 2006 1:58 PM
I have had a similar problem, but it was most definitely not a loose nozzle. Please, please, please, I urge you very strongly to take great care to clean the nozzle properly, each and every time. The first time I used mine, I didn't, and the paint caked on, and I was not able to clean it. I experienced the problem you described. Only thing I could ever do was to replace the nozzle. I've been using my A470 for about two years now. As much as people say you can't get good results with it, I disagree. It just takes a while to learn the nuances of this brush.
    March 2006
Posted by thetecman on Thursday, March 16, 2006 2:11 PM
Thanks zokissma I will bear that in mind, luckly I was just testing the brush with water whilst having these issues but thanks for the heads up and I will definatly look after my Tip!!
Posted by waikong on Friday, March 17, 2006 11:46 AM
Here's a tip I picked up from this forum when using acrylic (forgive me, i don't recall who orginally wrote this), after painting and shooting your favorite 'cleaner' thru the brush, just drop the tip into a small container of windex or something similiar. It can literally sit there for months with no harm. Take it back out for storage at some later date or even until the next time you need it. This brings my total clearning time to only about 2 minutes after a session - and no clogged nozzles, ever.
