Omni 4000 experts…
    January 2003
Omni 4000 experts…
Posted by Triarius on Friday, March 17, 2006 5:52 PM
Haven't used it yet—treating it like a new firearm. Shy [8)] Took it completely apart, put it back together. (No, I'm not going to teach myself to do it by feel in the dark! Wink [;)]) I have a few questions:
How tight fitting should the protective cap on the nose be? Mine is quite tight.
What is the purpose of the cut-out in the handle around the needle chuck?
The instructions do not say anything about adjusting trigger spring tension. It is obvious that it can be done, but what are the guidlines? Or is it just what feels good?
The instructions say nothing about lubrication. The instructions on the bottle of Backwards Badger Needlejuice are a little vague. What do they mean by "trigger chamber" and "needle chamber"?
Posted by MikeV on Friday, March 17, 2006 6:09 PM
Tight fitting cap is normal.
The cut-out is to allow you to pull the needle back inside that cutaway to clear any clogs in the nozzle.
Just adjust the tension of the spring to what feels good to you.
I put lube on the front half of the needle as well as a little on the sides and bottom of the trigger.
I also put a drop or two in the color cup and wipe it around to help paint not stick as bad there.
    July 2004
Posted by tho9900 on Friday, March 17, 2006 6:28 PM
Ross - first of all congrats!!!  Mike summed everything up, but on the trigger tension I recommend spraying awhile with the brush before changing the tension.  (Unless it just really bugs you the way it is now) I started messing with my first Badger and ended up putting it back the way it was the day I opened it eventually.  I found the slightly tighter tension allowed me better control of the paint flow as it helped keep me from doing any gross movement with my finger while tight in on the model trying to do detail... after you get used to it you'll have a better idea on whether you want it looser or not.
    January 2003
Posted by Triarius on Friday, March 17, 2006 7:35 PM
Thanks Mike and Tom!
So far, the only thing I'm not thrilled about is the shape of the trigger button—keeps slipping from under my finger as I pull back. (The skin on my fingers is normally so dry that I can handle a model as if I were wearing gloves—decades of water, rock dust, portland cement, concrete, and chemicals.)
I adjusted the tension so this does not happen. I may just dip the button in Plasti-dip.
Speaking of finger technique, do any of you use your thumb on the trigger button? I was just handling the thing, and this grip feels so natural…
    July 2004
Posted by tho9900 on Friday, March 17, 2006 7:48 PM
No but I seem to remember one or two here at one time who did that... go for what works for ya!  Get you a plastic 1 gallon jug, primer it and play with that bad boy and adjust your grip, the tension whatever ya want till it comes out right!  I do that with every airbrush I get now.. I like to get to know them before I spray on a kit.. (and no I don't have names for them...  well okokok... just one of them but she's special.. Wink [;)])
    January 2003
Posted by Triarius on Friday, March 17, 2006 8:06 PM
"She" huh? Is your "significant other" (talk about a silly euphemism!) jealous? Shock [:O]
LOL… Heck, I've got names for some of the other things I shoot with: Ding Chavez, Matt Quigley, Bill Tyler, …and Stupid Elf Tricks. Blush [:I]
Why not an air brush? Big Smile [:D] ……………I got it—Matthew Squigley! (shoots very accurately around very tight corners)
Blush [:I]Blush [:I]Blush [:I]…What was in that tea?
    January 2004
Posted by MusicCity on Friday, March 17, 2006 9:08 PM
You know, that cut-out is the one thing I miss in my Badger 100.  It's just really handy, especially with acrylics, to be able to pull the needle back and blow a gob of semi-paste paint out.  I've got an Omni 3000 I seldom use, wonder if it would fit.  I do like the slightly heavier weight at the back of the 100 though.
Posted by Torio on Saturday, March 18, 2006 7:08 AM
I changed mine for a Badger 100 one as I preferred it, and it seems to work.
Thank you all for coming José
Posted by MikeV on Saturday, March 18, 2006 12:58 PM
Ross,
The Anthem trigger will fit the Omni also so you could buy one and get the rubber finger pad that you put on the trigger with a drop of super glue. It is very comfortable and looks like this:
    July 2003
Posted by KJ200 on Sunday, March 19, 2006 9:52 AM
Scott, the rear section of my Omni fits my Badger 100 perfectly, but like yourself I prefer the extra weight of the solid Badger handle.
Karl
