I need high flowing Aztek nozzles
    November 2003
Posted by rudedog on Saturday, March 18, 2006 4:23 PM
I purcased  the best Aztekt they make along with they're see-thru compressor.I'ce tried the 2 nozzles they said were large areas & the 1 for high volumes of acrylic,and even trie the remaining 1's.But none produced more than small amouts of paint &spray.Any Idea & help will be great.   Semper fi, Rudedog
"...That's an order,not a debate topic , Sergeant Rudzik..."
    January 2003
Posted by scotty on Sunday, March 19, 2006 2:26 PM
Take a look here http://homepage.mac.com/srogers4/hobbies/models/airbrush/nozzles.html
I usually use the Black or White to spray large areas never had a problem, Also see if you can alter the pressure of your compressor and lower it to about 15psi.My 2 cents [2c]
Scott.
    November 2003
Posted by rudedog on Sunday, March 19, 2006 3:27 PM
Thanks Scotty.I think you hit the target.You see,I have a testors compressor that is at a fixed PSI output.Do you have opinions eithr way on a better & adjustable output compressor ? Thanks,rudedog
