advice on working with pearls
    May 2004
Posted by modelbuilder on Sunday, March 19, 2006 5:13 PM
I have been working a car and have decided what cooler to paint it. However I have never used any of the pearl colors from the Testors color by Boyd line. Any advice? What should I do for prep?
    January 2003
Posted by gburdon on Monday, March 20, 2006 8:12 PM
modelbuilder;
Ensure you have an entirely clean surface to paint on. Give your car a bath with mild detergent and let it dry overnight. Wear gloves (Latex type or similar) to check after it dries for any remaining deposit or grit. Check your seams etc. Once you've done the inspection and everything is set. Place your can of pearl in a container of warm tap water (Not Boiling) amd let it sit for a few minutes. Once the time has elapsed give the can a good shake and you're ready to go. Start and finish your spray off the model and mist the coats on evenly. Don't try and cover it all in one pass or one session. You can wet sand any drip marks out in between coats once dry. Continue the spray process until you acheive the finish and depth of finish you're looking for.
There are great articles in the back issues of FSM you may want to read. Or you could pay a visit to the sister magazine Scale Auto Modeler and view some posts on the forum there.
Hope this helps.
Cheers;
Gregory
VETERAN - (Noun) - Definition - One who signed a blank cheque as: “Payable to The People of Canada, Up To and Including My Life."
Posted by jhande on Wednesday, March 22, 2006 3:22 PM
I'd like to add just a little here.
I wipe down my models with Isopropyl Alcohol after the bath, right before I get ready to spray it.
Also I use a primer coat before spraying, especially any translucent or pearl type paints. Usually with the more translucent paints I use either silver, gold or sometimes white as my basecoat depending on the final shade I'm shooting for.
My 2 cents [2c]
-- Jim --
"Put the pedal down & shake the ground!"
