Are they the same thng ?
    January 2003
Posted by scotty on Wednesday, March 22, 2006 5:07 PM
Having just brought a bottle of  Tamiya X-20A thinner it smelt more or less like isoprponyl are they the same and am I just wasting more money buying the 'offical' brand, wouldn't they do the same anyway....as the Tamiya costs £5 for 250ml and iso costs £3.50 for double that on Evilbay.
Scott.
    January 2003
Posted by Triarius on Wednesday, March 22, 2006 5:18 PM
No idea whether they are the same or not—you cold try an MSDS search.
But 90 percent isopropyl alcohol is all I use to thin Tamiya paints.
    May 2005
Posted by Bgrigg on Wednesday, March 22, 2006 8:04 PM
I suspect the Tamiya thinner is isopropyl with an acrylic retarder. I find that paint thinned with only the iso dries very quickly, and can cause problems with "dry tip". Mind you I've used 99% iso, which is pretty darn pure!
So long folks!
    May 2004
Posted by albert_sy2 on Wednesday, March 22, 2006 10:13 PM
Actually the Tamiya thinner does not smell like IPA. IPA has a stronger, sweeter odor.
It's also true that if you use IPA in your paint it will dry up real fast, but the Tamiya thinner actually retards the paint a little bit. I will use the Tamiya thinner 50:50 to paint, but that's just me.
Groovy baby
Posted by Anonymous on Thursday, March 23, 2006 3:28 PM
Albert, what brush and what pressure do you use with that 50/50 Tamiya mix? How do you like the results?
E
    May 2004
Posted by albert_sy2 on Thursday, March 23, 2006 10:51 PM
^Sorry if you got the wrong idea... but I don't own an airbrush. I just discovered that for brush-painting, my usual mix of 50:50 works better than other ratios. Here are some of my previous works... they are not very good, but I hope you see how a simple brush with this ratio can be "good enough".
1:72 scale F-14
1:48 scale F-16
1:72 scale F-16C
1:72 scale F-18
1:48 scale Comanche
Groovy baby
    May 2005
Posted by Bgrigg on Thursday, March 23, 2006 11:07 PM
Albert, you can upgrade that "good enough" to excellent.
It's hard to believe you brush painted those models.
So long folks!
    May 2004
Posted by albert_sy2 on Friday, March 24, 2006 1:42 AM
^Thanks! Also, GSI Creos Mr Top Coat Flat and Mr Top Coat Gloss are some of my best friends! (Unless you guys can recommend a better overcoat spray?)
Wink [;)]
Groovy baby
    January 2003
Posted by Triarius on Friday, March 24, 2006 9:31 AM
Yah! What Bill said!! Wow!! [wow] If this is your "good enough," I'm not sure I'd want to see your "excellent!" I think it would make me weep with frustration. Boohoo [BH]
    March 2006
Posted by Yann Solo on Friday, March 24, 2006 2:37 PM
I was wondering if I had to go airbrush or not and I will make some tests on some little unfinished aircraft tonight but if I don't like it, I can clearly see that a wonderfull result can be achieved with regular brushing method.
Excellent job.
No matter where you go ....... there you are.
    January 2003
Posted by plasticmod992 on Friday, March 24, 2006 11:32 PM
Albert,
Man-o-man, no matter how many times I gander at your camouflaged F-16, I still can't belive it was "brush painted."  You've got skills!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
