tho9900 wrote: |
............... now I won't be able to sleep...
Gee thanks!!! |
Now you and me both Tom... thanks...
That's the third time I heard that explaination and it's still no easier to digest. LOL
Ok, so instead of sucking my milk shake through a straw, I need to blow
across the top of it really really hard and fast, I knew that. Ahh what
the heck, hook me up to an I.V. drip of chocolate milk. Oh wait... that
would be gravity-feed then... dang. Looky what you guys are doing to
me.
Andrew, I've seen and read about people doing some fantastic custom
work on helmets, motorcycles, autos, coaches, etc... using even a
single action gravity-feed. It all depends on the artists hand that
wields the tool. Most importantly - lots of practice.
Here's why for my first airbrush I went with an internal mix, dual action, gravity-feed -
Internal mix : better/finer atomization of the paint than external mix.
Dual action : better control over the spray pattern/amount of paint while spraying.
Gravity-feed : larger supply of paint for working on larger projects.
The airbrush I purchased can spray from hairline to 2 inch pattern with
no changing of needles and/or nozzles. The 0.5-mm self-centering
needle/nozzle is designed for spraying my heavier paints (textiles,
enamels, lacquers, etc...). Solvent based paints won't harm it. It
requires roughly .5 cfm @ 25 psi, but will spray really fine lines with
properly thinned paint at 5 to 10 psi (I've done it). A 0.35-mm
needle/nozzle is available, but Iwata told me it's not necessary for
the paints I'm spraying, I won't notice a difference. After I work with
this AB for awhile and get used to what it and I can do, I will
probably get myself a gravity-feed for fine detail auto work. Something
like an
Iwata Eclipse HP-CS or the more expensive
Iwata High Performance HP-C Plus.
I'm already contemplating getting another AB for my wife to use and/or
for just my son and I to use on our car models, something like that
Vega 600 single action gravity-feed at Badgers
garage sale for $20.
Iwata Eclipse HP-BCS Specs
Iwata Eclipse airbrushes at Dixie Art
