Many of you use airbrush lube and the subject comes up here now and then and so I thought I would add some things that I have done with it and see if you may want to try them also.
I know most people only use it on the front half of the needle and maybe a drop on the trigger where it touches the air valve, but I have found many other uses for it too.
I put a tiny amount on the sides of the trigger also where it contacts the channel in the body of the airbrush that it rides in. This seems to make it a little smoother.
It is designed to make paint not stick and so I use it to that advantage wherever I can.
I put a drop on my finger and rub it around inside the color cup to help paint not adhere to the cup as bad and make cleanup even easier. It does not affect paint so don't worry about doing this.
I hope this is helpful to someone.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
