Ok Greg I took your advice and bought Tamiya paints
Posted by MikeV on Sunday, March 26, 2006 10:13 PM
I went for a ride on my motorcycle and went to HobbyTown USA today and bought the Tamiya colors I will need for my P-47D as well as some denatured alcohol.
I haven't had a chance to try them yet and am excitied to see how they do.
    January 2003
Posted by plasticmod992 on Monday, March 27, 2006 3:04 AM
You're all set my friend!  I'd like to share some tips with ya, now that you've got the juice!
My thinning Ratios and airbrushing:
My prefered thinning ratio tends to be 2:1 for base coats at 15 psi and 1:1 at between 10 & 15 psi for fine line spray, camo, etc.  So far, my Iwata Revolution HP-CR, with it's .5mm tip can do everything for my 1/72nd scale jets, so I suspect your favorite Badger/ Omni, with it's similarly-tipped needle will be perfect.  I've also had excellent results with detailing by removing the needle guard on my Iwata, and I believe the Omini is designed around this concept- so you've taught us.Smile [:)]
I've also ditched the Polly S *Plastic Prep and began using the DNA in it's place.  Similarly, DNA cuts grease and oil very well from the plastic surface too and doesn't harm the plastic.  Turns out that Plastic Prep has Denatured alcohol in it with a detergent additive.  The back of the bottle says: "Contains Ethanol and Propylene Gycol Ether."  Now hows that for a coincidence!Wink [;)]
Primer and preference:
I've also experimented with primers.  There was no appreciable difference in the paint's adhesion characteristics as when I did not prime. Unless ofcourse, the model was a conversion with multi-media parts, heavy putty work, etc.  In this case, *Rustoleum Painter's Touch grey primer is my preferred choice.  I decant a small amount and prime the model with a light coat prior to the Tamiya colors.  This was a common practice, not nessessarily unique to my switch to Tamiya.  I prefer not to, but this is the only time I'll use an enamel lately.  I've recently tried priming with Tamiya Neutral Gray (XF-53) to eliminate the enamel. To my relief, I achieved the same results.
I'm very excited for you Mike, I hope this works out for you like it has for me.  The prospect of mixing colors made me apprehensive too, but I now appreciate it's advantages.  There's been alot of interest so far on this lesser known alternate thinner.  Shoot me an email if you run into any problems.  It's alot faster to send my refrerece pics to you in email than uploading to Photobucket.  Anyway, keep us updated and good luck sir!
Greg Williams Owner/ Manager Modern Hobbies LLC Indianapolis, IN. IPMS #44084
Posted by MikeV on Monday, March 27, 2006 11:44 AM
Greg,
Thanks once again for all the great info my friend.
I will post later in the day on my results.
Posted by MikeV on Monday, March 27, 2006 3:22 PM
Ok, I tried one color and am very pleased with the results.
I mixed XF-20 Medium Grey 2:1 with DNA and sprayed it on this scrap plastic at 15 psi with my Omni 4000.
The paint flowed nicely and reminded me a lot of enamels.
I can tell how fine the pigments are also by how smooth the overspray is in the photo.
So far I like them! Thumbs Up [tup]
Posted by MikeV on Monday, March 27, 2006 4:18 PM
I painted the bottom and posted a photo in the Aircraft forum under "My Tamiya 1/48 P-47D in progress."
I like this paint!
Posted by MikeV on Monday, March 27, 2006 9:34 PM
I put a piece of masking tape over this paint and burnished it down good and left it on for about an hour.
When I peeled the tape off no paint came up at all. I am impressed!
    May 2005
Posted by Bgrigg on Monday, March 27, 2006 11:40 PM
My, do we have a Tamiya convert in the making? Wink [;)]
So long folks!
Posted by MikeV on Monday, March 27, 2006 11:53 PM
Could be. Laugh [(-D]
Japanese paints through an American airbrush. Thumbs Up [tup]Wink [;)]
Posted by Anonymous on Friday, March 31, 2006 3:30 AM
I have been using Tamiya paint now for about 2 years and love the results.  I almost never use a primer even when painting invasion stripes or theater bands etc.  For masking Ill use anything from painters masking tape, Tamiya tape and BMF.  Gratz on trying Tamiya paint hers a link that has proved helpfull for mixing ratios in case you dont have it http://www.dana-nield.com/tamiya/default.asp
Posted by Anonymous on Friday, March 31, 2006 8:08 PM
Mike, did you have any problems with tip dry?
E
Posted by MikeV on Friday, March 31, 2006 10:16 PM
E
Not at all. I haven't painted large areas where a lot of paint goes across the needle but so far I haven't noticed any. I am impressed. Wink [;)]
