revell aqua paints
    December 2003
revell aqua paints
Posted by clc5@ryford on Monday, April 3, 2006 5:24 PM
I recently tried the newish Revell Aqua Colour range, mainly because I've become a little bit sensitive to petroleum based paints, thinners, cleaners etc.
I normally handbrush all interior parts (aircraft) so this is where I tested it. My initial impressions were very favourable.Good coverage, thin it as you like with water, sands easily if required (not like Tamiya which I find unforgiving) and virtually odourless!
Granted the colour range is limited at present, but it should be possible to obtain good WW2 colours matches with a bit of mixing.
If I can improve my brushwork to do the exterior parts (brushmark free), I'll be able to paint away in the living area with the rest of my family, instead of in the shed, spare room or garden with respirator goggles etc!
    April 2006
Posted by Mandrake2006 on Tuesday, April 4, 2006 2:47 AM
I'll be buying these new paints from Revell too. They are not available at the moment at the local hobbystore. I will use it with my airbrush.
It sounds good!
