Quick Compressor Question
Posted by Anonymous on Wednesday, April 5, 2006 10:36 AM
A quick question for the group.  Is a storage tank on the compressor important in your experience?  A Harbor Freight recently opened in my area and I am looking at getting the $50 compressor that has been much discussed on this forum.  On the other hand I can get a Coleman compressor mounted on a two gallon tank at Menards for around $65.  I already have a water trap, regulator etc. from my last set up.  I am using a Passche H and spraying exclusively acrylics.
One other question, not so quick!  I was using an Aztec and a 7 gal "carry" tank.  (My solution for Aztecs is to take it, wrap it up in the original box, and throw it out your window!!)  Has anyone rigged a compressor to an existing tank like this?  I presume you would need to get some sort of electronic shut-off switch or something?
Thanks in advance,
Nate
    April 2005
Posted by T_Terrific on Wednesday, April 5, 2006 10:58 AM
It depands on how much you want to do with your compressor and how much space you have.
The purpose of a storage tank is to allow the compressor motor to "cycle off" when it is full, allowing it to rest, and also allowing a larger volume to build up for large air consumption needs such as filling a car tire.
Facing the same decision myself, I opted for the simple $50.00 air brush compressor since I have small comressors for each of my car's tires as well as a minimum of space in my home for such things. I like how the Harbor Freight air brush compressor fits neatly into a little Igloo soft drink cooler I have, and I have not needed a spare tank with this compressor, as it seems to have more then adequate volume for my air brushes.
Hope this helps Wink [;)]
Tom T Cowboy [C):-)]
Tom TCowboy
“Failure is the opportunity to begin again more intelligently.”-Henry Ford
"Except in the fundamentals, think and let think"- J. Wesley
"I am impatient with stupidity, my people have learned to live without it"-Klaatu: "The Day the Earth Stood Still"
"All my men believe in God, they are ordered to"-Adolph Hitler
Posted by Anonymous on Wednesday, April 5, 2006 11:24 AM
Hope this helps Wink <img src=" src="/FSM/CS/emoticons/icon_smile_wink.gif">
Tom T
Yep, it helps!
I have read that another purpose of having the tank is that it "smoothes" out the air flow to the brush.  Supposedly pulses of air can come out of a compressor hooked direct to the airbrush and cause sputtering or perhaps splatters. (?)  Anyone have experience with this?
.I like how the Harbor Freight air brush compressor fits neatly into a little Igloo soft drink cooler I have
Do you do this just for storage or does it keep the noise down? Or is it for temp control?
Thanks,
Nate
    April 2005
Posted by T_Terrific on Friday, April 7, 2006 12:25 PM
 NESX wrote:
Yep, it helps!
Thanks,
Nate
Nate:
I use the cooler just for convenient storage, but also it keeps the unit free of nasty things between uses.
Personally, the pulses have not been an issue with me, but I use the inexpensive Harbor Freight dual-action air brush they used to have that was a Badger knock-off for $20.00 as well as their cheap external single-action external mixing unit for large areas, general priming, etc.
Just guessing, but I would think the pulses would be more of a problem if you were to seek to use the finer dual action brush "wide open" for a broad application, so that it would be more sensative to pressure pulses, where I find the external mixing single-action type suitible and easier to clean anyway.
At least that's my My 2 cents [2c]
Tom TCowboy
    December 2004
Posted by Hippy-Ed on Tuesday, April 11, 2006 11:41 PM
I guess I'll add my own My 2 cents [2c] worth here... I too have the Harbor Freight A/B(single action, external mix) & Compressor and I have no problems with them (other than the A/b feels awkward in my hand) I just discovered o the bottom of the water filter/regulator there is a valve to adjust the air pressureShock [:O] I've had it awhile & never noticed it before!Banged Head [banghead] I was trying to figure out how to drain off the moisture from the filter & found the knob  befroe discovering the "valve stem"  release.
 By this time next week I'm hoping to have a Badger 175 hooked up to itBig Smile [:D]
If you lose your sense of humor, you've lost everything
